Check engine light with rough idle....#4 cylinder problem?
Hey guys
I've a check engine light on last night after a long run
The car runs fine and still pulling strong. However on idle the car shakes quite a bit, especially after long highway driving. The rpm stays steady on 1000 at idle but you just feel the car keep shaking.
I also notice the shaking occurs after I changed to Mobil 1.. Shouldn't the engine supposed to idle more smoothly after changing to synthetics?
I wonder would it be the dreadful #4 cylinder problem? What are other symptoms of misfiring?
Please advised.
Alex
Please advised.
Alex
When the check engine light is on, the ECU is running on a pre-programmed fuel map that ignores the various sensors. This alone can cause a rough idle. This doesn't usually affect hard acceleration because wide open throttle (WOT) ignores the sensors also. Get it checked out soon! It could be all sorts of things.
Paul(UK)
Dec 3, 2009 03:21 AM
