Check engine light woes
Old Jun 29, 2011 | 01:35 PM
  #21
nartnailuj's Avatar
cuz the blinking the cel is doing is how it blinked when i pulled the code.
Old Jun 29, 2011 | 02:14 PM
  #22
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'm not sure. I think when its flashing/running, it is not flashing a code. I never sat and counted flashes...only when pulling.
Old Jun 29, 2011 | 02:16 PM
  #23
nartnailuj's Avatar
oh ok bc it is flashing the code and i been counting and its been the same code over and over. i dont know if it is suppose to blink or flash the code. I guess i'll get it towed just to be safe
Old Jun 29, 2011 | 02:26 PM
  #24
nartnailuj's Avatar
yeah i think its the code flashing because the eps light is flashing too
Old Jun 30, 2011 | 01:08 AM
  #25
mmm...vtec's Avatar
i know in OBD1 cars that it was possiable to count the CEL flashes and get a code...i think some early OBD2 cars this is possiable as well...but to be sure what the code is hook up a scanner....
Old Jun 30, 2011 | 03:04 AM
  #26
dagle's Avatar
if its blinking while driving, its your knock sensor picking up the misfires. it is not reading out the code to you, it's telling you to pull over. plug#1 don't look too good. swap the plugs to the new ones, and even if it runs well, keep your old plugs from cyl #2-4 for now. There's a good chance whatever smoked the #1 plug will present itself again in the future and your old plugs will be useful to diagnose. Find the misfire thread and diagnose it accordingly, could be many different things.
Old Jun 30, 2011 | 07:00 AM
  #27
Billman250's Avatar
Top Answer: 1
Knock sensor has nothing to do with misfires.
Old Jun 30, 2011 | 01:23 PM
  #28
spa01s2k's Avatar
A friend of mine was battling a misfire with his S2000 recently. We did a bunch of tune up stuff: new plugs, cleaned out the throttle body, fuel pump sock, valve adjustment, injector cleaner, and cleaned his air filter. This didn't help the misfiring problem (the misfire was all across the RPM range). His car has 175,000 miles, we swapped in some injectors with 20k and the misfire was gone. He has driven the car another 2000+ miles without a problem.
Old Jun 30, 2011 | 01:28 PM
  #29
liquidtek's Avatar
He forgot I changed all 4 coilpacks too
Old Jun 30, 2011 | 02:24 PM
  #30
dagle's Avatar
Cool
