check engine from test pipe
Old May 12, 2004 | 12:13 PM
allenheathdj's Avatar
http://www.wiredspeed.com/itemdesc.asp?ic=...2DO2SIM&eq=&Tp=
does anyone have a diagram on how to hook up the simulator?
Old May 12, 2004 | 12:14 PM
oh yeah, the car only requires one correct?
Old May 12, 2004 | 12:17 PM
Gernby's Avatar
Former Sponsor
You only need one, and it comes with a basic diagram. You will need to determine the connections that need to be made at the ECU using a Helm's manual. I recommend installing it inside the cabin at the ECU, so that the OEM O2 sensor harness doesn't have to be messed with.
Old May 12, 2004 | 12:27 PM
vvtli78k's Avatar
just drive it with the cel light on, don't make any diff.
Old May 12, 2004 | 12:31 PM
Gernby's Avatar
Former Sponsor
That is probably not true. I noticed a significant drop in fuel economy before I installed my O2 simulator. I have also read that the ECU continues trying to fix the problem (improve catalytic efficiency by heating up the cat with extra fuel). It would also prevent you from knowing about future CEL codes.
Old May 12, 2004 | 02:09 PM
CHEETAH_S2K's Avatar
I really think the CEL affects performance cause ever since I put my testpipe, my et has dropped a good 4/10s ... 13.9 vs 14.4/14.5's I aslo changed wheels/tires and thought it was traction but i cut the similar 60' times so it couldn;t have been.
who knows.
greg
Old May 12, 2004 | 03:30 PM
sirrach's Avatar
can you install the simulator without cutting into the wiring harness?
Old May 12, 2004 | 05:57 PM
JAYZS2000's Avatar
Thanks for all your input. I am still driving it with the light on and since I have I can tell I'm getting worse gas mileage. I am still not sure the best route to go, but I may look into the o2 sim.
Jason
Old May 13, 2004 | 09:50 AM
Gernby's Avatar
Former Sponsor
Well, the "best" route is to get an aftermarket ECU that ignores the 2nd O2 sensor. However, the most practical and equally effective route is to get the simulator.
