Clicking
Old May 12, 2009 | 04:56 PM
Olegator's Avatar
I had to get a new one.... old one was shot.
But it does not necessarily mean that you have the same problem, get it looked at.
Old May 12, 2009 | 06:30 PM
AusS2000's Avatar
I had a clicking. Replaced and torqued axle nuts. Still there.
Replaced axles, click is gone.
Old May 12, 2009 | 06:45 PM
esmith51's Avatar
It seems to be coming from the right axle. I have one ordered. Hopefully this will fix the problem. I'll post pics. Also, I'll make sure to check for wear on the inner cup on the old part and post pics of any damage. If it still clicks i could always replace the left side inner cup with the one from the old part from the right side. Did they change the material it was made out of on the later MY or was the problem alleviated by the geometry changes on the later suspension.
Old May 12, 2009 | 07:11 PM
04 S2000's Avatar
My clicking sounds like it changes every time, sometimes it comes from the left side or it'll come from the right side and I have a AP2 so I guess its not just on AP1's.
Old May 13, 2009 | 07:44 AM
PanteraKitty's Avatar
My car first did this in June 2008. Sounded like something rubbing - maybe brake pad or warped rotor. Finally took it to a shop and they found a TSB about greasing the spline.(Outboard end of left rear axle) Worked fine for 5 or 6 months. They greased it again in December 2008 using some marine grade lithium grease.
Tomorrow I take it back to them for the 2009 greasing. This time we will try a new nut.
Is there a permanant cure for this problem?
Anyone else have to do this every 5,000 - 6,000 miles?
Old May 13, 2009 | 08:13 AM
rudeboy1313's Avatar
Can some one put a picture of what needs to be torque. I have the same noise from the right side of the car, seems to be right under the driver side. i thought it was a relay at first. . I think it's the same problem everyone is having.
Old May 13, 2009 | 11:39 AM
istdercollen's Avatar
take your wheel off
look for the thing in the center
it has a little piece of metal that is dented in. Undent it.
torque to 220 lbs/ft
Old May 13, 2009 | 11:56 AM
ohhhh,, i feel like a dummy... thanks
Old May 13, 2009 | 02:28 PM
i just took mine off, and was like . i dont have one!! then i figure , ohhh my axles are in the back. , hey it's my first rwd honda. what size nuts is that, anyone. i have to buy one cause my biggest socket does not fit. Also found out my torque wrench only goes up to 150. damnit.
Old May 13, 2009 | 02:40 PM
it's 36mm. just search for your info next tie.. there's also a torque & spec thread somewhere in the under the hood stickies I believe. hope the torquing is all you need to do!
