Clicking noise need help have vid
Old May 12, 2009 | 08:40 PM
Fatman13's Avatar
Default Clicking noise need help have vid
Ive had this horrible clicking noise for a while now i got a new tct and adjusted my valves but its still there. i used the old screw driver trick and i can here a loud click if i put the screw driver in the higher hex key bolt (not the one for the tct) and also it sounds like the noise is coming from the fuel rail. Heres a video with the camera over the rail any ideas let me now also during the video the car almost stalled wich has never happend before.
http://www.youtube.com/watch?v=7DpqLVAHLlw
thx guys
Old May 13, 2009 | 02:35 AM
lotus7racer's Avatar
Identifying the source of the noise is always hard.
...but what I can hear is a "consistent" knock in the engine. I can hear a sound similar to a spun a bearing?
Regardless...it's a consistent sound. If you progressively raise the rev from idle to hi, is the sound all the way?
Old May 13, 2009 | 11:12 AM
Fatman13's Avatar
pretty sure cant here it in v tec cuz my exhaust is so loud so your saying its a bad bearing?
Old May 13, 2009 | 11:24 AM
Definitely inside the engine....but I'm only guessing the sound similar to a spun bearing issue. You said, you have a new Timing chain installed, so we can rule that out.
I asked to rev it slowly (from idle to hi). Is the sound present all the way to hi rev?
I listened a few times...sounds a bearing.
Old May 13, 2009 | 12:15 PM
IlleztImportz's Avatar
the ticking is consistent regardless of the revs, it sounds like. hmm
Old May 13, 2009 | 06:00 PM
bgoetz's Avatar
Ouch!!, that does not sound good at all . My initial guess is that is rod knock, from a bad rod bearing. However, there have been people who have changed out the timming chain tensioner and have not put the gear back properly and got a noise from that. But you said it had the sound before you changed the TCT, so....... Let me see if I can't find where I found a reference to the gear issue.
Old May 13, 2009 | 06:11 PM
bgoetz's Avatar
here is the thread, the last post talks about the other possible issue, to bad the OP video does not work.
https://www.s2ki.com/forums/index.ph...pic=694688&hl=
From what he describes and what I hear from your video, it does not sound like the same thing though. Unfortunately, I really think that is a bad bearing. What is the story behind the engine (miles, oil changes, f#ck ups, etc.)??
Old May 14, 2009 | 11:00 AM
Fatman13's Avatar
i bought the car used so idk wat the other guy did to it i bought it at 60k miles and now it has 64.
Old May 14, 2009 | 12:11 PM
SILAP1's Avatar
definately an internal problem maybe bearing or bent valve
Old May 14, 2009 | 05:31 PM
bgoetz's Avatar
Do you know if he was running boost or anything, because that engine sounds screwed . I almost want to say he would have had to have known something was up when he sold it.
