clocking timing chain gear.
Old Mar 17, 2009 | 02:12 PM
crave13k's Avatar
Default clocking timing chain gear.
i have a quick question. when clocking the cam chain sprocket to compensate for a thicker head gasket (3mm) do u clock the gear that is on the actual chain or the gear that drives the cams? also clockwise or counterclockwise. thanks
-J
Old Mar 17, 2009 | 02:23 PM
negcamber's Avatar
Is this for an FI car?
Old Mar 17, 2009 | 04:48 PM
Slows2k's Avatar
You remove the solid pin from the upper chain sprocket. You don't do anything to the cam gears.
Bruunz
Mar 27, 2017 03:59 PM
slociviccoupe
Mar 17, 2009 04:45 PM
PeanutButter
Mar 4, 2008 11:30 AM
