Clunky-ness from the front end?
Old Aug 8, 2019 | 11:31 AM
yamaha6611's Avatar
Default Clunky-ness from the front end?
The front end has always made these strange "clunk" noises... only when you hit little tiny bumps or different road surfaces. Always scares me thinking its tie rods or A arms but they're new and good.... anyone else getting this? Steering rack bushings maybe? Anything notorious im unaware of?
Old Aug 8, 2019 | 11:33 AM
engifineer's Avatar
Is it modified at all? Front sway? Shocks/springs?
Old Aug 8, 2019 | 12:32 PM
Car Analogy's Avatar
Rule out simple stuff like swaybar end links.
Old Aug 9, 2019 | 10:03 AM
yamaha6611's Avatar
okay, yeah it does have springs and shocks on it... i noticed the same sounds with my other s2000 as well, never really tracked it down with that one either. ill check the sway bars
Old Aug 9, 2019 | 10:29 AM
Say Chi Sin Lo's Avatar
You should check out my similar issue:
https://www.s2ki.com/forums/s2000-br.../#post24627399
After ruling and replacing what I have already, I suspect I may have blown front passenger side damper, and blown rear driver side damper.
The car drives fine other than the annoying clunks and visible streak-like stains on the mentioned wheels.
Old Aug 9, 2019 | 01:17 PM
Hondassport's Avatar
My 06 did the same thing when I bought it,every time I hit a tar strip it went clunk, found the upper nut on the front drivers side sway bar drop link was loose took me two minutes to tighten and no $$$. now is quiet...Pete
Old Aug 11, 2019 | 05:38 PM
Fastisfun's Avatar
At what speeds does this happen?
Old Aug 12, 2019 | 08:15 AM
For me, it's most evident 30mph and below.
EVEN more so when I'm at "looking for parking" crawl speed.
Old Aug 23, 2019 | 01:04 PM
yamaha6611's Avatar
Found it! Rear A-arm bolt wasnt hand tite, but loose enough that when i hit the wheel with my hand it would replicate the noise. Tightened... back to normal! Let's hope my alignment is still on point lol
Booti
Jul 27, 2017 02:24 AM
JonBoy
Feb 12, 2016 04:09 PM
Ajval79
Nov 8, 2013 05:16 AM
toyrunner
Sep 30, 2011 03:54 AM
pakman08
13
May 14, 2009 01:00 PM
