Cluster is blinking !
Old Apr 16, 2008 | 09:42 PM
BOODINzO''s Avatar
Default Cluster is blinking !
Hello guys,
i have a problem that once i start my car the cluster blinking !! .. and if i step on the gas it work normal ...
any ideas why and how to fix it ???
Old Apr 16, 2008 | 09:44 PM
qbmurderer13's Avatar
Is it just while the car is cranking or does it stay blinking once its on? If it happens while your starting it its normal, but if it flickers then it could probably be your alternator going out.
Old Apr 16, 2008 | 10:32 PM
BOODINzO''s Avatar
i know its normal while is cranking, but no its blinking if am not driving the car plus its only the main cluster the radio and every thing working normally. ??
Old Apr 16, 2008 | 10:44 PM
AslanS2K's Avatar
have you tampered with it? any bad connections? have you installed a new radio recently? if so the dimmer (or orange or orange with white stripe) wire in the aftermarket radio may need to be disconnected if you used it. Also, there may be an incorrect wiring if you installed a new alarm. If its none of these, the LED's in your cluster may be going, and causing shorts. If all that has failed, the dimmer switch on the cluster. or the headlight switch may need replacement
Old Apr 16, 2008 | 10:51 PM
BOODINzO''s Avatar
no new radio but may from the headlight because i switch the rear bumber with the new 2006 wih the lights ... but is was working fine , recentlly i faced this problem ....
Old Apr 16, 2008 | 11:06 PM
BlownAP's Avatar
If it is flickering at idel but goes away when you rev your engine than your alternator is on it way out, get a new one before it leave you stranded.
Old Apr 20, 2008 | 02:45 AM
BOODINzO''s Avatar
Thanks Guys
Old Apr 20, 2008 | 06:14 AM
oheim's Avatar
Might not be the alternator, I have the same problem on my 07 with 14k miles. I swear to the Honda Gods if my alternator is going out already I will punch Honda right in the face!
Old Apr 20, 2008 | 06:35 AM
txs2knoah's Avatar
most likely its the alternator going out.
are you running a system ?
Old Apr 21, 2008 | 08:44 AM
oheim's Avatar
Now that I think about it when I put my Alpine 9857 in I definitely connected the dimmer wire.... I bet that is my problem
