Clutch disengages while accelerating
Old Dec 1, 2015 | 02:39 PM
Recluse129's Avatar
Default Clutch disengages while accelerating
I posted problems I was currently having with my car when I first bought it here: (Below)
https://www.s2ki.com/s2000/topic/113...#entry23751680
However I am not sure if the problem I have currently is a cause from something In my previous post.
While leaving my street I live on today I did a small pull to 7k rpm in 2nd gear, It felt as if my clutch disengaged and the car revved to the redline and nose dived a little as if it wanted to stop then the clutch engaged again after letting off the gas, then I switched into 3rd gear and continued to drive as if nothing happened.
The event happened really quickly for a split 2-3 seconds, Thereafter the car drove as if nothing ever happened.
This same even has happened twice before, exact same scenario while merging on the free way a couple times with me revving it in the higher rpms.
I spoke to my mechanic who replaced the clutch kit & he told me its the master cylinder for the clutch? He doesn't know too much about these cars as its the first s2000 he worked on, So I figure to ask here for second advice.
Thanks.
Old Dec 1, 2015 | 03:25 PM
yamahaSHO's Avatar
Sounds like it is slipping.
Old Dec 1, 2015 | 04:05 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Over adjustment of the master push rod can cause this, be sure you have free play that you can feel with one finger.
Old Dec 1, 2015 | 05:06 PM
Soviet's Avatar
Does the problem surface on every WOT pull to redline?
Old Dec 1, 2015 | 05:21 PM
Recluse129's Avatar
Thanks, Just got it changed too.
Will check it out tonight, thanks!
Most of the time, yes. Between 6-7k.
Distracted S2000
Feb 10, 2018 04:49 PM
JEvansS2k
Nov 26, 2014 08:48 PM
stakss2k
Mar 26, 2014 05:51 PM
stwoki
Feb 24, 2011 07:15 AM
jstar
Dec 20, 2006 11:58 AM
