Clutch - Do I need a GUIDE, RELEASE BEARING
Would I need the Guide for the Bearing? It's a 30 dollar part and I'm told it shows wear, but do I really need it?
GUIDE, RELEASE BEARING - 21103-PCY-003
Thank you!
Thank you!
I didn't replace mine. Some of the early S2000's didn't seem to have enough lube on the clutch systems so it is possible to have some wear on the guide.
If it just has some shiny spots that you can't feel with your finger I'd say keep it, just put some proper lube on it. If you have damage as listed above by cdelena or stuff that you can feel with your finger (scoring) then replace it.
Upon assembly fill the throwout bearing inner recess so it is flush with Honda Urea Hi-temp grease and it will be lubed for the life of the part.
I have a 02 with like 60k on it, I'm only changing the clutch since I've upped my hp/tq. I'm thinking it should be good.
Originally Posted by CoolGuy094' timestamp='1397690472' post='23116297
I bought one to replace mine before I got the trans down, and I was really glad I did. My old one was extremely scored from the TO bearing running dry on it.
