clutch fluid
Old Apr 23, 2015 | 01:24 AM
S2KBert's Avatar
Default clutch fluid
OK where can I buy clutch fluid at and which one would you recommend also would I need brake fluid also and how do I replace the clutch fluid
Old Apr 23, 2015 | 03:15 AM
Chuck S's Avatar
Try the maintenance section, details are there. Clutch fluid and brake fluid are the same thing.
My owners manual states:
Always use Honda Heavy Duty
Brake Fluid DOT 3. If it is not
available, you should use only DOT 3
or DOT 4 fluid, from a sealed
container, as a temporary
replacement.
... and yours does too.
-- Chuck
Old Apr 23, 2015 | 05:49 AM
jimi's Avatar
This stuff: http://www.amazon.com/ATE-706202-Ori.../dp/B003VXRPL0
Old Apr 23, 2015 | 06:08 AM
redlineracing's Avatar
I use Prestone DOT 4 brake/clutch fluid in all my 5 cars and use the turkey baster to change it at every OCI.
It's a good DD fluid.
\rlr
carolina
Old Apr 23, 2015 | 10:22 AM
S2KBert's Avatar
So I should use the the dot 3 from the Honda genuine or does the 2004 s200 use dot 4
Old Apr 23, 2015 | 10:39 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you can get your hands on ATE super blue or ATE Type 200, the fluid life in the clutch system is phenomenal, as is it's resistance to leaking or getting dirty.
Old Apr 23, 2015 | 02:19 PM
S2KBert's Avatar
Is it possible to still buy the ate super blue what's the difference from the original honda genuine dot 3 to that one
Old Apr 23, 2015 | 05:42 PM
windhund116's Avatar
No, you can't buy Super Blue ATE brake fluid in the US, anymore. Govt regulations about the color of brake fluid. I beleive that the yellow ATE brake fluid is just as good as the blue. I replaced both brake and clutch with ATE Typ 200 yellow. So far so good.
Old Apr 24, 2015 | 01:43 AM
S2KBert's Avatar
Would you recommend then type 200 yellow or the the oem honda
Old Apr 24, 2015 | 02:17 AM
Slowcrash_101's Avatar
Either is fine.
