Clutch fork concern
Old Dec 25, 2015 | 03:50 PM
madcowdk's Avatar
Default Clutch fork concern
I am working on putting everything back together after replacing my clutch. However, the clutch fork will sit in the keeper like it is supposed to, but I feel like it pulls back out too easily. I have even replaced the metal clip inside the keeper and yet it still seems that the fork comes out too easily. Am I just being too paranoid about this? I hate to button everything back up and have not corrected this, if it's a problem.
My thoughts are that it will be fine when the slave and everything is hooked back up, but just want to be sure.
Any thoughts on this?
Thanks!
Old Dec 25, 2015 | 06:39 PM
Soviet's Avatar
When I put mine back together the clutch fork would come out extremely easily to the point where it was frustrating... I think you're OK but should wait for someone else to chime in.
Old Dec 25, 2015 | 08:48 PM
rmerchant3's Avatar
Spot on
Old Dec 25, 2015 | 10:21 PM
99SH's Avatar
As a sanity check, just confirm the receiving ball pivot is not deformed or worn down. There's plenty of preload from the slave cylinder to keep things in-tact.
Old Dec 26, 2015 | 04:37 AM
madcowdk's Avatar
Great info guys! Thank you!
This makes me feel better about proceeding with putting everything back together.
Thanks again!
Old Dec 26, 2015 | 01:06 PM
FlyingTR's Avatar
After I got the clutch changed, I had to get the transmission opened again because of the fork, it made a weird noise and pedal felt wrong.
Its 60 on Majestic Honda so really not that expensive. Also check the release bearing guide for wear(30$), which in my case is the reason to open it 3rd time.
This dude on youtube somewhat shows it, mine was a little bit worse than that, and it had wear on the pivot point.
https://www.youtube.com/watch?v=2GkWdHfFkjk
Old Dec 27, 2015 | 01:38 PM
madcowdk's Avatar
Awesome!
Thank you!
tehsu
Jan 4, 2011 12:42 AM
Gh0ztt
Feb 18, 2008 06:43 PM
Pezza
Nov 27, 2007 10:15 PM
ajkewler
Jan 9, 2006 11:36 AM
