clutch issue
Old Feb 23, 2010 | 09:46 PM
hypforlife32's Avatar
Default clutch issue
i have an 01 ap1 with 58k on it. i just replaced the master cyl and slave cylinder about 800 miles ago. my clutch grabs really high and i dont know if this is normal or not. right after i replaced both master and slave it grabbed hard about an inch and a half off the floor(perfect) but not 800 miles later-maybe 1k later its back to up top again. really high, clutch doesnt slip in any gears. not from a stop nor from a launch either. shouldnt my clutch be grabbing an inch off the floor all the time?
Old Feb 24, 2010 | 05:17 PM
zherbo's Avatar
I have a 2002 bought new always released high from new, had a new clutch put in under warrenty, i now the tech so we tried to put a act clutch kit in and it would not disengage, trans out agaain put the oem clutch in and worked fine but released high, that normal on my car
Old Feb 24, 2010 | 05:50 PM
DFWs2k's Avatar
you can change engagement by adjusting the cable
Old Feb 24, 2010 | 06:46 PM
how do you adjust the cable??? that would help out alot
Old Feb 24, 2010 | 07:22 PM
zherbo's Avatar
What cable, theres not one on the clutch ?
Old Feb 24, 2010 | 07:56 PM
Slows2k's Avatar
No such thing as a clutch cable on a S2k...
Old Feb 25, 2010 | 02:07 AM
alricl's Avatar
search 'clutch adjustment' as gernby on here had previously posted some good info on how to adjust your clutch engagement etc to improve shifting.
Old Feb 25, 2010 | 04:25 AM
mlc's Avatar
mlc
If you have replaced the CMC then adjusting the engagment point is pretty easy. There is a locking nut on the shaft from the clutch pedal to the piston. Loosen the nut and turn the shaft to adjust it. Don't turn it more then say a half a turn at a time and then check it. There should be about on inch of play at the top of the pedal. If you adjust it to far it will mess up the clutch itself so take it easy.
You might also want to rebleed the system while you are at it.
Kevin
Old Feb 25, 2010 | 05:17 PM
RedY2KS2k's Avatar
How does one adjust the clutch cable on an S2000? Inquiring minds want to know.
Old Feb 25, 2010 | 11:40 PM
rocsix's Avatar
theres a bolt behind the blutch u can twist to adjust. there are post with pictures too without spending too much time on the search button.
I have a 02 which grabs pretty high.
my friends 00 grabs REALLY low. i honestly liked driving with lower engagement.
anyhow, i've heard that adjusting the clutch might not be the best thing, especially when it comes to replacing your clutch. something about the alignment or something i dont remember. can anyone clarify?
