clutch issues
Old Nov 3, 2010 | 08:30 PM
jon_353's Avatar
Default clutch issues
My clutch all of a sudden has alot of free play in it. It engages/disengages about an inch off the floor with the rest of travel being free play. Anyone know why?
Old Nov 3, 2010 | 08:37 PM
whitebrad25's Avatar
check the fluid/bleed/change it...thats what it is sounding like.
when was the last change?
Old Nov 3, 2010 | 08:38 PM
if the problem popped up out of no where, the car still engages and disengages fine, it is more than likely your fluid. it will get worse quick, you should do the bleed soon. there is a great DIY on the forum and it is an easy job
jon_353's Avatar
havent changed it. will check fluid tho.
Old Nov 3, 2010 | 08:39 PM
ya, its your fluid. had the same problem about a month ago....good
p.s. if the fluid change does not help, check into the clutch master cylinder/slave
you can get them from this website cheap
http://www.hondaautomotiveparts.com/auto/j...KA6MT&catcgry5=
just fill in the drop down menus
Old Nov 3, 2010 | 08:40 PM
jon_353's Avatar
yeh still engages and disengages. thx for the help. Was about to ban wife from driving it lol.
Old Nov 3, 2010 | 08:41 PM
haha i would avoid driving it, but it isnt a big deal if it isnt the DD. it will wear the clutch unessecarily if you do drive with this problem though
here is the link to the DIY
http://forums.s2kca.com/showthread.php?t=12154
Old Nov 3, 2010 | 08:47 PM
jon_353's Avatar
awesome, appreciate the help.
Old Nov 4, 2010 | 07:00 AM
osidis's Avatar
same here. just a bleed. i was pissed off because i was about 400 miles from home. thought i had to replace the clutch. it was hard to change gears without pumping the clutch. i checked the reservoir, is was empty. pulled my car up on the ramp and had a buddy help keep the reservoir full as i flushed the line. DO NOT GET FLUID ON YOUR PAINT. good luck.
Old Nov 4, 2010 | 04:33 PM
the link i gave, if he reads it, is very adequate.....it mentions the ability of DOT 3/4 to eat paint etc...but ya, that is how this happens, if it has never happened to you, youll always expect to have to buy a clutch but fortunately, it only takes one experience from this before it is the first thing you will check..i had air in the lines and that was enough to engage at the floor. happened immediately without warning. easy job takes little time. the fluid in mine probably wasnt changed for 4-5 years....it was nasty black, the fluid gets nasty quick anyways...but i swapped ALL fluids shortly after the few first weeks i owned the car. now im on a clean slate
