clutch kit components
Old Jun 11, 2013 | 04:25 PM
jyang315's Avatar
Default clutch kit components
Hey all, I'm trying to compile a list of the components that would be necessary to get my clutch replaced at the mechanic. Trying to save a few bucks by ordering my own parts, instead of having the mechanic buy them. I was initially going to go with the Exedy OEM clutch kits available on the internet for around $350 or so, but it seems like buying OEM parts from hondaautomotiveparts.com is probably a better idea. Assuming I will get my flywheel resurfaced, can you guys let me know if there is anything I need to add (or remove) from this list?
1) Friction Disk (22200-PCX-055) - $110.92
2) Pressure Disk (22300-PCX-015) - $224.92
3) Clutch Release Bearing/Throwout bearing (22810-PCY-003) - $94.65
4) Pressure Plate to Flywheel Bolts/9 of them (90034-689-000) - $4.04x9=$36.36
5) Flywheel to Crank Bolts/8 of them (90011-PCX-B01) - $3.16x8=$25.28
Total: $492.13
Again, not sure if everything on that list is necessary, so let me know. Also, if I'm wrong in assuming that ordering these parts separately from hondaautomotiveparts.com is better than getting the KHC06 Exedy OEM clutch kit, let me know as well.
Thanks.
Old Jun 11, 2013 | 04:27 PM
s2000ellier's Avatar
you can reuse your flywheel and PP bolts, buy new drive shaft bolts instead
if you are reusing your flywheel buy a new flywheel pilot bearing
Old Jun 11, 2013 | 05:00 PM
Murphg05's Avatar
^^^this. bolts should be fine, but the pilot bearing will keep the input shaft from flopping around. Not sure how much they are on the S, but should be pretty cheap!
Old Jun 11, 2013 | 07:00 PM
slowd16's Avatar
pilot is ~$14. no reason not to at that price. Do not do the exedy oem replacement. I picked one up a few weeks back and the springs were loose and rattled when shaken. Sent it right back and just ordered the oem disk from honda. Also only use honda bearings. The other manufactures tend to go bad quicker.
Old Jun 11, 2013 | 11:17 PM
S2KiChad's Avatar
^^x2 on the buy driveshaft bolt as they are VERY easy to round
Old Jun 14, 2013 | 09:05 AM
jyang315's Avatar
Thanks for the responses guys. For the flywheel pilot bearing, would it be part# 91006-PCX-008? Link is: http://www.hondaautomotiveparts.com/...atcgry5=CLUTCH
Also, can any of you tell me what the part number for the driveshaft bolts are, and how many I would need?
Lastly, I see that there is a washer listed on the clutch system (90429-PCX-000). Is that necessary?
In summary, sounds like this is what I need:
1) friction disk
2) pressure plate
3) throwout bearing
4) flywheel pilot bearing
5) driveshaft bolts
6) possibly washer?
Old Jun 14, 2013 | 09:41 AM
CoolGuy094's Avatar
You can reuse your existing washer (90429-PCX-000)
If you are replacing the throw out bearing (which you should) you should go ahead and replace the throw out bearing guide as it is likely scored up. Its like $26 but worth it. Mine was all scored up and rough when I replaced my clutch. Part number is 21103-PCY-003.
FWIW I reused my driveshaft bolts too.
Old Mar 20, 2018 | 12:45 AM
altimatic's Avatar
Exclamation
whats the code of the drive shaft bolt.
Old Mar 20, 2018 | 03:50 AM
B serious's Avatar
this question gets brought up once every week.
Don't forget your release bearing guide and HT urea grease
Old Mar 20, 2018 | 04:30 AM
Slowcrash_101's Avatar
Get a new rear main seal just in case.
nismo300zx
Jan 26, 2009 03:51 PM
bjonesz28
Jul 30, 2008 05:33 PM
jaehoppa
Jul 21, 2007 06:19 AM
jaehoppa
Jul 20, 2007 11:48 PM
jaehoppa
Jun 15, 2007 01:12 PM
