Clutch OEM?
Old Oct 31, 2017 | 09:49 AM
Andythiing's Avatar
Question Clutch OEM?
just joined and first thread so apologies in advance if I should have found this in another thread. Did have a look. Picked up my first S2000 today MY 2000. Also first time Honda owner. Mechanically very good apart from needing a new set of spark plugs and the clutch is on the way out. Looking for advice on anything I need to ask about having clutch fixed. Car is unmodified and I’m not looking to track/race it’s just a weekend cruiser. Will an OEM clutch be the way to go - any advice on what I should check with the shop - a local shop I’ve used for 30yrs.
Old Nov 1, 2017 | 03:57 PM
GSteg's Avatar
OEM clutch, pilot and throwout bearing is the only way to go if want OEM reliability and quietness. It may even be quieter than your current setup if your car still has the original disk (those were suspect to buzzing upon deceleration).
Make sure they grease the input shaft spline with Honda hi-temp urea grease.
Old Nov 1, 2017 | 05:53 PM
Andythiing's Avatar
Thanks gsteg for the response - have booked her in and asked for all OEM parts - also asked them to check on correct oils/grease etc but will contact them now to check they use the hi-temp urea grease
Old Nov 3, 2017 | 02:41 AM
Andythiing's Avatar
Got my upgrade OEM clutch fitted - big change
01ap1allday
Dec 7, 2020 03:37 PM
smokenrowboy
Jun 19, 2009 03:08 PM
UMaineEECE
Jul 20, 2005 03:59 AM
2_and
Jun 18, 2004 07:09 AM
dhess
Apr 8, 2002 04:43 AM
