Clutch Pedal Modification
Old Apr 26, 2014 | 01:36 PM
s2k14's Avatar
Default Clutch Pedal Modification
(2003 S2000)
Not entirely sure what to call the issue that I'm having, but I'll try to describe it...
In order for the clutch to grab, I have to let the pedal out about six inches. I've never owned a manually driven car
before so I thought this might be the norm. But while watching a friend of mine driving his civic, I noticed he only
had to let off his clutch pedal less than half that, about two inches or so. With or without buying some sort of kit,
am I, and should I be able to modify it so the clutch grabs much closer to the floor? Preferably with my left heel still
touching the floor.
Thanks in advance, and excuse my ignorance if applicable... lol
Old Apr 26, 2014 | 02:21 PM
stupkid's Avatar
Keep your clutch pedal where it's at. That's normal, but if you want to adjust it go under the footwell where the clutch pedal meets the master cylinder through the firewall and adjust it there.
Sent from my SGH-M919 using Tapatalk
Old Apr 27, 2014 | 05:46 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Trying to adjust for preferred pedal height is a bad idea.
If your clutch is grabbing high, you have a worn out disc plain and simple.
Old Apr 28, 2014 | 05:49 PM
Back S2k's Avatar
^x2
Old Apr 29, 2014 | 08:42 AM
jWESTFOO's Avatar
I'm not sure what you mean by "grabbing high". For instance, I don't have to depress my clutch pedal very much for my clutch to engage, and I have to release my clutch pedal most of the way out for my clutch to disengage. Would this be considered grabbing high?
Old Apr 29, 2014 | 08:54 AM
iamxpl's Avatar
^^ yes thats exactly it. high in the pedal travel.
Old May 1, 2014 | 12:43 PM
jWESTFOO's Avatar
Huh. That seems counter intuitive to me. I would think that less pedal travel means there is less displacement required to make the disc contact which would mean a thicker and fuller disc. Would there be any noise or behavior that would go along with a worn out disc?
Old May 1, 2014 | 01:14 PM
vtec9's Avatar
It's all relative. In my opinion, the S2K naturally grabs "high" compared to some other cars, but it takes someone with experience to know if it grabs "too high". I don't have to depress my pedal a ton disengage it, and I never did.. certainly not to the floor.
Old May 2, 2014 | 04:42 PM
Slowcrash_101's Avatar
After about 100,000 miles these clutches start getting stiff and the engagement comes later in the pedal release. It's normal, it's called wear, even if you drive perfect and never abuse the clutch or transmission, they'll go about 100,000 before they start showing signs of wear. The smoother you drive the more you can milk it.
StrokerSi
Aug 10, 2017 06:26 AM
drewc
Sep 9, 2015 02:12 AM
nemesis2k
Oct 31, 2010 08:10 PM
Tneltn
Dec 14, 2008 12:06 PM
Gh0ztt
Feb 18, 2008 06:43 PM
