CLUTCH PROBLEM, HELP!
Old Feb 25, 2011 | 01:03 PM
SickAP1's Avatar
Red face CLUTCH PROBLEM, HELP!
Alright so i recently picked up my 00 s2k and ive notice that when i drive without having t0 press the clutch as much its okay, but lets say if i go to a drive-thru or a parking lot with alot of speed bumps and i have to engage the clutch multiple times i notice sometimes the car when i put it on first to go it acts like its lagging. But once i get it in gear and i drive without having to press it as much it will be good. Im not sure if this makes any sense but if anyone has the same problem and fixed it let me know please! thanks
Old Feb 25, 2011 | 06:48 PM
SickAP1's Avatar
anyone?
Old Feb 25, 2011 | 07:57 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Don't understand. At all.
Old Feb 25, 2011 | 10:12 PM
realblag's Avatar
Sounds like your clutch is worn and slipping. Please give better details of your problem.
Old Feb 26, 2011 | 05:09 AM
SickAP1's Avatar
Alright lets say i go out on a drive and i dont have hit traffic or i dont go in a place where i have to keep pressing the clutch (like stop and go multiple times) When i do press the clutch a few times after a couple times the car acts like it doesnt grab or lags...but if i give it enough gas and i just keep driving it gets better. Its pretty hard to explain im trying my best to make it easy on you guys to understand. So pretty much i dont have to keep getting on the clutch the clutch as much in short period of times it acts alright, but if in a short period of time i engage and disengage the clutch a few time thats when the problem happens. I tried changing the fluid out and put new Honda MTF but still does it sometimes.
Old Feb 26, 2011 | 07:02 AM
DFWs2k's Avatar
.....the clutch doesn't use MTF...that's for the tranny...
Old Feb 28, 2011 | 10:00 PM
SickAP1's Avatar
im pretty aware of that buddy, the whole flush thing was for the tranny. But im talkin about my clutch probllem. Tranny was flushed to see if changes would occur since the clutch is also part of tranny.
Old Mar 1, 2011 | 02:47 AM
SilverS2kF22C1's Avatar
Thread is so full of fail...
It is not clear what you are saying... Changing the tranny fluid will not do anything to fix the clutch... Fluid goes inside the tranny clutch lives on the outside of the tranny box... Changing the fluid may help with notchyness not whatever you are trying to say with the clutch...
Are you saying that the clutch is slow to engage when it gets hot? So you get a lot of RPMs before it engages? Are you saying that the motor bogs down after a bit and the car doesn't want to accelerate?
Old Mar 1, 2011 | 12:33 PM
splatter85's Avatar
Get cruising to about 20-30 mph. Put it in 6th, then floor it. If the car starts reving up but isn't going any faster than your clutch is slipping and needs to be replaced. If the car acts normal and slowly accelerates then its probably another problem. Check your plugs and wait til you get a new batch of gas in the car to see if the problem goes away, and try to explain the issue a little better next time. You jump all over the place and ask too many questions at the same time mixed in with other statements.
Old Mar 3, 2011 | 05:09 PM
whiteflash's Avatar
Well we'll start with the basics... has the clutch ever been replaced, either by you or a previous owner? If it has... I would suggest making sure that it was replaced with AP1 (or better) spec'd equipment. I'm assuming it'd bolt up (although I don't know) but using a AP2 flywheel and/or pp probably wouldn't produce the best results in a ap1.
That being said, if anything it sounds like you just have poor clutch technique. It sounds like you're causing a minor glaze from repeated (poor) clutch use, and that final grab it slips a little bit. Does it ever free-rev or actually hang? During non-repeated clutch use?
