Clutch Problems
Old Jul 23, 2007 | 07:38 AM
c blues 02s2's Avatar
Default Clutch Problems
Alright yesturday i left work for a break to get something to eat. so i get in my car and realized the clutch pedal has at least 50% play in it. so i pumped the hell out of it thinking it might help but still nothing. i drove to grab a bite to eat and it felt like 30-40% of the pedal was being used. so after work when i got home i check my clutch fluid and it was nearly empty all the way to the bottom and very dirty. so i went and got some fluid. i filled it up and capped it then pumped the hell out of it again. then the clutch pedal felt like it was back to normal. when i bought the car there was a tiny bit of play in the pedal maybe you could press it down an inch not even. thats how it felt again after i filled it up. so i drove about 7 miles to the gas station and on the way back about 9 miles into my trip it starts feeling really loose adn playful again. i havet gotten a chance to check the fluid level again but i will right after work and i'll update you guys. please let me know what you think.
thanks,
cory
Old Jul 23, 2007 | 08:35 AM
anyone?
Old Jul 23, 2007 | 11:39 AM
can anyone help me? do i need to bleed the clutch system or what? please help!!
Old Jul 23, 2007 | 01:07 PM
90crvtec's Avatar
The fluid doesn't just disappear on it's own. It is pretty obvious that you have a leak. Start pricing a slave cylinder.
Old Jul 23, 2007 | 03:00 PM
is this covered under warranty?
Old Jul 23, 2007 | 03:09 PM
90crvtec's Avatar
Why don't you take it in and see? How the hell should I know?
Old Jul 23, 2007 | 06:25 PM
sorry just wondering if you knew. wasnt asking for an asshole remark
Old Jul 23, 2007 | 11:35 PM
SIIK2NR's Avatar
Where's the update on the fluid levels?
Most likely you have a leak somewhere or you let the clutch fluid get too low and even though you have filled it up, there is air in the line and needs to be bled ouit.
Old Jul 24, 2007 | 06:39 AM
sorry guys, yeah the clutch fluid is full. so im guessing theres air somewhere in the system. im gunna bleed out the whole system after work with all new fluid.
Old Jul 24, 2007 | 05:08 PM
90crvtec's Avatar
Sorry you don't have a sense of humor kid, the internet can be tough these days.
And you're missing the point here. Your fluid went SOMEWHERE. It doesn't just get low at random intervals. You might have temporarily stopped a problem by adding fresh fluid but you're still left with the original question of "where'd all the fluid go the first time?". You can start with checking all around the slave/master cylinders for leaks. Also look for signs of wetness under the clutch pedal, sometimes fluid leaks past the clutch piston inside the footwell.
If your car has a warranty (I assume it does or you wouldn't have asked the first time) then I'd start attempting to use it.
