Clutch Problems (Slave Cylinder?)
Old Feb 9, 2012 | 12:08 PM
John''s Avatar
Default Clutch Problems (Slave Cylinder?)
So I took my car to class yesterday and the clutch was perfectly fine. About 6 hours later after work and the gym (located next door to my job) I came out and started my car. I immediately noticed the clutch had A LOT of play at the top of it. I drove it home and the clutch engaged perfectly fine, didn't slip out of gear at all. This leads me to believe the slave cylinder is the culprit. Also i should note that it seemed like the clutch was engaging a little closer to the floor then usual. What do you guys think could be the issue?
UPDATE:
I finally got around to checking out this issue when i got home today. Looks like its actually the CMC, it's leaking fluid.
Sorry for the quality it was kind of an odd picture to take.
Thanks for any and all input.
-John
Old Feb 9, 2012 | 12:41 PM
lltysonll's Avatar
Check Fluid to see if it is low or dirty, then try a bleed of the fluid.
http://forums.s2kca.com/showthread.php?t=15696 (this shows you how to change CMC and where the leak occurs near clutch pedal.) Do a bleed first.
Old Feb 9, 2012 | 12:42 PM
lltysonll's Avatar
http://forums.s2kca.com/showthread.php?t=12154
How to bleed.
Old Feb 9, 2012 | 12:46 PM
John''s Avatar
Thanks! I do it right after work. Say the fluids low, it could still be a leak in the slave cylinder because it shouldn't lose fluid, correct me if I'm wrong.
Old Feb 9, 2012 | 04:49 PM
John''s Avatar
Looks like you were right. Should i still try to bleed them first or just change out the CMC?
Old Feb 10, 2012 | 05:59 PM
John''s Avatar
I flushed the fluid then bled the air out and the clutch if fine...actually better then when I got it back in October. Cmc no longer drips just had clumpy fluid with some air in the system. Glad I tried that before replacing the cmc saved me a hundred bucks and a lot of time. Thanks for the diy on bleeding the fluid!
Niuniu32
May 3, 2017 03:10 AM
vtecowner
Mar 10, 2013 06:54 AM
hellspare
Jan 12, 2010 01:34 PM
epaplia
Oct 20, 2008 10:16 AM
Suzukuh
Dec 3, 2007 01:47 PM
