Clutch Sensor
I'm trying to find the honda part number for the clutch sensor. I broke the little black rod while adjusting my clutch pedal.
Originally Posted by TookayS2K
(Post 21033917)
TookayS2k,
You must be referring to the clutch switch assembly. I've heard of some individuals erroneously refer to it as a sensor but Honda officially refers to it as the clutch switch. The OEM p/n is indeed 35710-SE3-A01 but I've also heard that the TEC unit is OEM so theoretically it should work too. It's part number is 36760-SE0-003. Just for your reference, the clutch switch assembly is illustrated as ref #9 in the diagram below: http://www.hondapartsnow.com/diagram...dal-462389.png *diagram courtesy of hondapartsnow.com; all rights reserved |
That's exactly what I needed to know. Thanks guys. I needed to find the clutch switch.
Do you guys know what problems that broken sensor will cause? I haven't even had time to see if the car starts up or not. |
should stop the car from starting
The car starts. Cruise control doesn't work. I'll just wait till somebody does a part out and get it for cheap. :thumbup:
