Clutch Sensor
Old Oct 3, 2011 | 01:51 AM
TookayS2K's Avatar
Default Clutch Sensor
I'm trying to find the honda part number for the clutch sensor. I broke the little black rod while adjusting my clutch pedal.
Old Oct 3, 2011 | 04:31 AM
T-Smac's Avatar
Do you mean the clutch switch? If so, it's OEM part number is 35710SE3A01. Costs about $46.00
Old Oct 3, 2011 | 07:43 AM
stook00's Avatar
TookayS2k,
You must be referring to the clutch switch assembly. I've heard of some individuals erroneously refer to it as a sensor but Honda officially refers to it as the clutch switch. The OEM p/n is indeed 35710-SE3-A01 but I've also heard that the TEC unit is OEM so theoretically it should work too. It's part number is 36760-SE0-003.
Just for your reference, the clutch switch assembly is illustrated as ref #9 in the diagram below:
*diagram courtesy of hondapartsnow.com; all rights reserved
Old Oct 3, 2011 | 09:15 PM
TookayS2K's Avatar
That's exactly what I needed to know. Thanks guys. I needed to find the clutch switch.
Do you guys know what problems that broken sensor will cause? I haven't even had time to see if the car starts up or not.
Old Oct 4, 2011 | 04:35 AM
T-Smac's Avatar
should stop the car from starting
Old Oct 4, 2011 | 04:31 PM
TookayS2K's Avatar
The car starts. Cruise control doesn't work. I'll just wait till somebody does a part out and get it for cheap.
mikey430
May 5, 2013 08:08 AM
NGR
24
Jun 21, 2010 09:54 PM
2000sx
Oct 30, 2006 11:39 AM
ChuckS2k
Dec 18, 2001 06:57 PM
