Clutch sticking after heavy rain
Old May 19, 2017 | 12:34 PM
Reguile's Avatar
Default Clutch sticking after heavy rain
So was driving home after it rained heavily, drove through a pretty flooded area.
Anyways, the next day, I feel my clutch is sticking at the initial engagement point.
Sticking as in actually being stuck and I have to break it free at the engagement. I also notice that the higher the engine is revving, the harder it is to break free when I push the clutch in.
I have greased the fork before in the transmission after removing the boot with the honda hi temp grease. Just curious what I should be looking for when I get back under my car? Thank you guys
Old May 19, 2017 | 06:11 PM
steelers743's Avatar
On my phone so can't find the link but search for the sticky clutch fix thread. You need to pull the clutch fork and polish/regrease it
Old May 23, 2017 | 09:50 AM
Reguile's Avatar
Well. Driving home last night, my clutch went out and it went out really quick. Couldnt accelerate anymore when i got home.
my clutch is still relatively new, has about 10,000 miles on it.
Old May 23, 2017 | 10:24 AM
Soviet's Avatar
What clutch kit did you buy?
Old May 23, 2017 | 01:09 PM
Reguile's Avatar
Exedy khc06c. Thinkthe basic one cause i planned on leaving it stock.
tryingg to figure if the clutch is bad or somethin is goin on with the transmission that caused it to fail.
Old May 23, 2017 | 01:18 PM
Soviet's Avatar
Aftermarket clutch kits have been known to fail prematurely, especially the release bearings and then later the clutch discs. Is your clutch slipping? Can you still push your pedal all the way down? Can you get into gear?
Its unlikely that the transmission is at fault. Possibly clutch failure or install issue (leading to glazing friction disc).
Old May 23, 2017 | 11:30 PM
Car Analogy's Avatar
Its the disk. A spring has fallen out. All Exedy clutches fail this way, usually after 20k miles or so.
Don't make the same mistake again.
Honda disk
Honda release bearing
Honda pilot bearing
Honda or Act pressure plate
If you didn't replace the release bearing guide last time, do that now.
Old May 24, 2017 | 01:05 PM
Reguile's Avatar
My clutch does nothing but slip and it happened quickly. Clutch still goes in all the way. Can still put it in gear.
Old May 24, 2017 | 01:07 PM
Reguile's Avatar
Honda disk
Honda pilot bearing
honda disk is what failed in the first(defective) place but still seems like the best route.
Is the release bearing also called the throwout bearing? I did have that replaced and have a spare.
Old May 24, 2017 | 01:12 PM
Soviet's Avatar
Thumbs down
Could be a poorly adjusted clutch master cylinder (installer error) or possibly improper break in... Hmm. How hard do you drive?
