Clutch vibrates in Vtec...
Old Sep 6, 2003 | 05:06 PM
tjohn's Avatar
Default Clutch vibrates in Vtec...
Now that my S is finally getting broken in (1100 miles) I'm starting to rev it a bit. Today around 6000 to 6500 rpm I'm getting this vibration while shifting. Doesn't seem to happen every time though? Anyone know what this is?
TJ
Old Sep 7, 2003 | 08:52 AM
hygiene boy's Avatar
Look at the heat shield between the header and battery. Is it close or contacting and other metal parts? You can bend it slightly in any direction if it is the vibration. It did this in both my brother's S2000 and mine as well. If not good luck finding the problem.
Old Sep 7, 2003 | 11:41 AM
tjohn's Avatar
Thanks! I'll try it.
TJ
Old Sep 8, 2003 | 09:51 AM
Gernby's Avatar
Former Sponsor
Many S2000 owners (myself included) report that their clutches are noisy (rattly) when disengaged that can be felt in the pedal. Mine has had a rattle for 30K miles without getting better or worse.
Old Sep 8, 2003 | 10:17 AM
iceple's Avatar
[QUOTE]Originally posted by gernby
[B]Many S2000 owners (myself included) report that their clutches are noisy (rattly) when disengaged that can be felt in the pedal.
Old Sep 8, 2003 | 10:25 AM
Gernby's Avatar
Former Sponsor
If you are concerned about it, take it in. They will likely tell you it is normal (since it probably is).
Old Sep 8, 2003 | 02:41 PM
tjohn's Avatar
Yeah, it's definitely a vibration from the engine reving. I tried shifting today at 6500, as soon as I touched the clutch pedal I could feel it vibrating (not a rattle). Haven't tried adjusting the heat shield yet but I can't see that causing the pedal to vibrate in such a manner. But who knows??
TJ
Old Sep 8, 2003 | 07:07 PM
vodalus's Avatar
It's normal.. Mine does it too.. I took it to the dealer and they showed me the same noise coming from another brand new one. . nothing to worry about.
Old Sep 8, 2003 | 07:09 PM
If you hear a vibration it could be the heat shield , if you feel it too it's probably the clutch.
TonyY510
Nov 20, 2003 06:02 PM
1337 S2K
Jun 6, 2003 08:24 PM
shannow
Jun 3, 2003 05:18 AM
TTSUPRA
May 3, 2002 03:34 PM
