cmpression leak down on s2k?
Old Aug 16, 2006 | 03:19 PM
macspeed704's Avatar
Default cmpression leak down on s2k?
what's the average compression leak down on s2k
Old Aug 16, 2006 | 04:46 PM
SuzukaS2OOO's Avatar
MY02 ran:
213,217,219,218
38k miles
Old Aug 16, 2006 | 06:35 PM
Slows2k's Avatar
A compression test and a leakdown test are 2 different things, with different results.
Leakdown is expressed in a % of leakage. 10% leakage on each cylinder is considered acceptable. The cylinder is pressurized with air, with all the valves closed and the pisaton at TDC. The 2 gauges on the tester show regulated inlet pressure, and the pressur ein the cylinder. The difference is your leakdown %. 100psi inlet, 95 psi outlet = 5% leakage.
Anymore leakage than that you get to find where the air is going. Past the valves, rings, valve seats etc. etc.
A compression test only measues the output pressure of the piston in the cylinder. it doesn't allow you to check cylinder sealing. The "new" spec is 228psi. minimum is 135psi,max variation is 28psi.
Must be measured at 250rpm, and WOT. You need a good battery that can power the stater to spin the engine quickly, and hold the throttle wide open.
TvoS2K
Feb 1, 2021 05:31 PM
datlexgs300
Feb 14, 2013 05:42 AM
Elistan
Sep 7, 2012 08:22 PM
S2K
Mar 14, 2009 11:41 AM
FormerH22a4
May 31, 2005 08:23 AM
