Code P0116
Old May 5, 2013 | 03:28 PM
Clark's Avatar
Default Code P0116
So I just got done putting my engine back in after pulling it out the .... unplanned way (intake, head, block, leaving all wiring in the car/in the way) and all is swell except for one problem.
I threw a code P0116: Engine Coolant Temperature Circuit Range/Performance Problem. The symptoms seem to be:
first, it may have showed 3 bars when I started it, I don't recall
As I let it idle and warm up, it'll eventually just climb in temperature until it overheats.
The engine coolant fan never comes on.
So what did I forget to plug in, break the wire or sensor on?
Old May 5, 2013 | 03:32 PM
apme123's Avatar
make sure you dont have air in your cooling system, make sure its bleed properly with billmans method
Old May 5, 2013 | 03:48 PM
Clark's Avatar
Thanks apme123, though still wouldn't account for the code (which was thrown immediately) or the fan not coming on.
Old May 8, 2013 | 05:16 AM
Clark's Avatar
aw c'mon, where's Billman? Working on paying jobs instead of remotely solving mine for free?
Old May 11, 2013 | 05:09 AM
Clark's Avatar
seems silly in retrospect. I cleared the code and restarted and it's all gone. I'm pretty sure the code was thrown because there was no coolant at the sensor yet, so it was just in air and threw the 'out of range' code.
JSanford2032
Apr 28, 2019 11:54 AM
InlinePRO
Jan 16, 2018 12:36 PM
hawkman199
Oct 30, 2016 12:18 PM
EOE
May 30, 2009 01:19 PM
