Coilover problem seeking advice
Old Sep 28, 2008 | 11:16 AM
x s2k x's Avatar
Thumbs up Coilover problem seeking advice
Hi, I was wondering if I could get some advice regarding my left rear coilover. I started lowering the car yesterday just to balance height from all four corners. In doing so, I could not lower the rear left side due to the fact that the body of the coilover would not spin. I released the lock at the bottom and left the top part lock the same. I also decided to uninstall the coilover just to see if I can twist without any weight from the car.
Apparently, the only thing that I can twist at the moment is just the springs itself. The body of the coilover would not spin at all. Has anyone ever had this problem? What can I do at this point?
Thanks,
Rod
Old Sep 28, 2008 | 05:31 PM
SOHCmyDOHC's Avatar
It would help to know which CO's you have. Just spray penetrant and let it sit for a while then try again.
Old Sep 28, 2008 | 06:59 PM
x s2k x's Avatar
Sorry...it's the Apexi EXV's...So just lube it and let it sit for awhile? Would it be because of corrosion?
Thanks
Old Sep 28, 2008 | 11:35 PM
SOHCmyDOHC's Avatar
could be corrosion or could be dirt on the threads.
Old Sep 29, 2008 | 06:47 AM
x s2k x's Avatar
If the top circular locks are on tight, would I be able to use this to spin the body of the coilover once lubricated enough?
Thanks again.
Old Sep 29, 2008 | 03:05 PM
Rdizzle's Avatar
Instead of adjusting this yourself, I highly recommend you take your car to get corner balanced (and alignment). This will ensure that your ride height is truly even (takes into account your weight and even things like how much gas you have).
It was a night and day difference in handling after I had my car corner balanced and aligned.
Old Sep 29, 2008 | 11:02 PM
SlipAngle79's Avatar
Thanks again.
Just so you know - if your gonna try to work it loose you rgoing to use a penetrant, not a lubricant. PB blaster wroks great on seized stuff.
Old Sep 30, 2008 | 07:11 AM
x s2k x's Avatar
Oh...thank you! I will try tonight. I did pick up a couple bottles of PB Blaster, and hope it would do the job.
Thank you.
edumak
Jan 4, 2017 12:39 PM
TougeS2k
Sep 9, 2012 10:49 AM
HonCBRf2
Oct 28, 2011 11:39 AM
KillerCom
Jun 23, 2011 07:33 PM
tuannguyen
Oct 14, 2010 03:28 PM
