Cold shifts
Old Oct 18, 2009 | 05:12 PM
GregFarz78's Avatar
Thumbs up Cold shifts
I've noticed this getting worse as its getting colder out 1-2 and 2-3 shifts are pretty notchy then as it warms up it gets smooth. Is this just normal? Its got about 14k miles and I doubt the trans fluid has ever been changed. Would it help to switch to a synthetic trans fluid?
Old Oct 18, 2009 | 05:22 PM
rob-2's Avatar
Normal. Read other postings on this topic.
Do switch the fluid out, it'll be an improvement.
Old Oct 18, 2009 | 05:30 PM
hellspare's Avatar
I just shift slow when it's cold.
Old Oct 18, 2009 | 06:49 PM
ahrmike's Avatar
lol@thread.
At first I was wondering WTF only 8K miles on an 01??? then I noticed the date...
Btw, IF you DC 1-2 shift, it will considerably lessen the notchy shift.
Call me crazy, but more than just me will attest to it fixing the problem.
My theory (as an engineer, you always need a theory... but this is a after the fact theory a possible explanation for why it works)
is:
1) it gives the input shaft time to slow down, so just shifting it to N, then waiting a sec, then popping it into 2 might work just as well
2) it forcibly slows the ip shaft down when you clutch out in N since the engine revs drop.
3) a mixture of 1&2.
Btw, fresh TF is a must for silky smooth shifting... I <3 Redline MTL, others love Honda MTF, GM Friction Modified Syncromesh, Redline MT-90...
Just try a few, pick one that fits YOU & your climate & your driving habits...and you'll love the s2k shifting action.
from other thread.
DC = double clutch = shift out of 1, let off clutch, clutch in again, shift into two
Old Oct 18, 2009 | 06:57 PM
Ch0pper's Avatar
Yes, changing the fluid may help (go ahead and change your diff fluid while your at it). Also when it's cold out, while warming the car up, I actually depress the clutch and row through all the gears before actually taking off. I started doing this after I read about another member doing it. Seems to help IMO.
Old Oct 18, 2009 | 07:49 PM
AP2Berlina's Avatar
its common..just shift slower so you don't get the grind and as someone else said new fluid could help a little
Old Oct 18, 2009 | 08:28 PM
skeithr's Avatar
i agree, its pretty normal, fresh mtf will help
Old Oct 19, 2009 | 03:11 AM
GregFarz78's Avatar
Originally Posted by ikeyballz,Oct 18 2009, 06:49 PM
from other thread.
ah damnit not double clutchin like I should be
thanks all just wanted to make sure, I'll have to change out the fluid soon
Old Oct 19, 2009 | 05:12 AM
takeshi's Avatar
I'd recommend changing it at 15K or earlier. Honda MTF is good.
Old Oct 19, 2009 | 05:31 AM
Random1's Avatar
+1 for the Honda MTF. It works as good as the GM Synchromesh Friction Modified and lasts longer. I change mine every 10-12k.
I was only getting about 6k out of the GM Synchromesh Friction Modified
