Cold starting issues...help
Old Aug 12, 2011 | 01:23 PM
steven975's Avatar
Default Cold starting issues...help
Lately, my car has been sluggish starting when left overnight. It's in FL so it gets close to 100 then falls into the low 70s overnight.
The battery is new and the oil is full (well, down maybe 1 X on dipstick). 2002, 75K, SOS Stage 1 supercharger.
The starting is a little sluggish. It does start, but it takes a few cranks, and the engine runs really rough for about a second until it seems the air pump and the normal working logic of the ECU takes over. Oil light is on for about a second...could it be the oil is not "sticking" to things well?
The car idles VERY well, and runs VERY smooth, and makes GREAT power, so I don't think it's shot rings or anything. There's Mobil1 in it now, and I'm not happy with it as the usage is high (1Qt/1K). Before this fill (NOT M1), the usage was minimal, and I have some Castrol Titanium ready to put in.
I pulled my plugs last weekend. They appear normal...no buildup on the electrode, no visible oil on them, all the same color, ground prong a little white...nothing alarming there. On the threads, on all 4 cylinders, there appears to be what is oil on them, but I think it's actually heavy hydrocarbons from unburned gas. All 4 pistons are very dark when shining a light on them.
Now, here's the video of the car starting when left alone 24 hours. I normally blip the throttle when starting to prevent that "roughness" but if I don't, the video below is what happens. I did NOT blip the throttle...the ECU/air pump takes it to ~2K to warm up the cat.
[media]http://www.youtube.com/watch?v=VEezI4XKB5w[/media]
The next video is a start immediately after the last one...all normal. It starts like this when it heats up and when cool for the rest of the day. The roughness only happens when left overnight and the temp drops.
[media]http://www.youtube.com/watch?v=KvlgN9CLqmc[/media]
So, any thoughts about what it could be? Perhaps just changing oil will fix this? Could it just be condensation in the cylinders due to the temp change?
Old Aug 12, 2011 | 01:42 PM
Round 3's Avatar
Battery sounds kinda weak.
change plugs
Old Aug 12, 2011 | 02:52 PM
steven975's Avatar
plugs are only about 5 months old. I'll probably go to some NGK Iridiums one step colder, though. I'll also test the battery. Battery is about a month old...but I'm thinking it could be a dud...will get it tested.
Old Aug 12, 2011 | 11:39 PM
k_lude's Avatar
sounds fine mine sometimes cranks like that also...might be cranking power in battery???just my thoughts though sometimes crank power doesnt really matter
Old Aug 14, 2011 | 07:28 AM
steven975's Avatar
Took it to Autozone when dumping some used oil.
Their tool says battery and alternator are good, starter failing. Well, gonna be doing a clutch soon anyway; I can replace it then.
Couna777
Feb 3, 2016 09:08 AM
Owen_1987
Oct 16, 2010 02:19 AM
ChaseBaciles
Oct 15, 2010 10:09 AM
nicholasbartleet
Sep 13, 2009 08:10 AM
superjimbo
Feb 24, 2006 09:32 AM
