Combo clutch question!
Old Jan 17, 2006 | 11:25 AM
DannyInKorea's Avatar
Default Combo clutch question!
Hi,
Can I use OEM Clutch cover with EXEDY Metal Clutch & TODA Flywheel?
Is it a good combo?
Old Jan 17, 2006 | 03:23 PM
Slows2k's Avatar
You shouldn't use the flywheel or pressure plate in the picture. Both are heat checked badly, and you won't be able to resurface either.
Contact Exedy for a pressure plate reccomendation, chances are they won't reccomend the OEM pressure plate.
Old Jan 17, 2006 | 04:16 PM
jerrypeterson's Avatar
From the picture it is impossible to determine if there is heat checking. Definitely looks like transfer though. If this is the same clutch or the same compound I wouldn't see a problem (based upon the quality of the picture).
Any chance we could get a close up picture of the contact surfaces? Why are you replacing the clutch in the first place?
Don't forget to buy new bolts before installing!
Old Jan 17, 2006 | 05:03 PM
Slows2k's Avatar
Looks like heat checking on my monitor
Old Jan 17, 2006 | 05:39 PM
Greenlight's Avatar
If you really want to accelerate your car quickly, order a Wolfe Racecraft clutch assembly. It's much much lighter than anything else out there.
Old Jan 17, 2006 | 05:49 PM
Slows2k's Avatar
greenlight, are you using a stock S2000 trans in your dragster?
This the clutch you are using?
Old Jan 17, 2006 | 10:16 PM
Thanks guys!!!
How much is the Wolfe Racecraft clutch assembly?
and streetable?
Old Jan 18, 2006 | 09:20 AM
Heat checking is fine cracks in a cross-hatch pattern. Discoloration is normally the transfer of friction material to a surface.
Old Jan 18, 2006 | 10:44 AM
Old Jan 18, 2006 | 11:33 AM
cntcu's Avatar
is that the toda flywheel pictured?
there are crazy heat marks on it, and i would have it resurfaced if i were you...you can use the oem pp with the toda flywheel and exedy clutch
