The common 1-2 grind
Old Sep 4, 2004 | 08:09 AM
Dolemike2's Avatar
Default The common 1-2 grind
Hey I have the all too familiar 1-2 shift grind. I have taken note however that I can shift at 8k to 8.5k and not grind BUT if I shift at 9k it will grind almost everytime. Just curious if that should be taken as a headsup for the clutch starting to get weak or if I have a syncro going bad. I changed the tranny fluid with GMSFM and it seemed to have gone away temporarily but now its back. My thoughts were that if it was the syncro it would do it at almost any rpm range rather than being on the high end of the powerband where there is more stress on the clutch. ???
Old Sep 4, 2004 | 10:41 AM
RT's Avatar
RT
does not sound clutch related by your description ....... how exactly would a "weak" clutch play in to the scenario?
Old Sep 4, 2004 | 11:31 AM
Dolemike2's Avatar
The amount of hp it is handling while shifting at that point?
Old Sep 4, 2004 | 11:35 AM
RT's Avatar
RT
"it's" not "handling" any HP while the clutch pedal is depressed ......... you are pushing in the clutch while shifting, right?
Old Sep 4, 2004 | 12:47 PM
Road Rage's Avatar
When was your last tranny lube replacement, and what did you use?
chrisn
May 28, 2007 07:32 AM
heffergm
Mar 7, 2004 03:49 PM
