Compression Check
Old Mar 2, 2007 | 02:38 PM
B.Money's Avatar
Thumbs up Compression Check
hey guys iv searched around but cant really find exact how-to on doing this. i went to sears a little while ago and saw something on checking compression but how can i be sure is the correct thing???
Anyway can someone tell me exactly how to run a compression check because i have no idea what im doing lol thanks guys!
Old Mar 2, 2007 | 03:09 PM
crackaonrice's Avatar
here's some non-s2000 specific info that you might find helpful:
http://64.78.42.182/sweethaven/MechTech/Au...sNum=7&modNum=6
The test is relatively easy to do even if you are not particularly mechanically inclined, but as usual, be sure you know what you're doing before you dive in.
Old Mar 3, 2007 | 10:03 AM
blackout's Avatar
basically remove all the plugs, screw in the compression tester and crank it over with the tester in each plug socket...just make sure you take all the plugs out
Old Mar 3, 2007 | 02:35 PM
B.Money's Avatar
should i leave 3 plugs in and the compression tester or 0 plugs and the tester? lol sorry guys im like hard core newb when it comes to this
Old Mar 3, 2007 | 02:51 PM
bluegas68's Avatar
Take out ALL the plugs. You dont want any compression resistance. The engine needs to be able to spin over freely with no restrictions. Then screw in the compression tester. get in the car and hold the throttle wide open. Turn the engine over several times ( i usually do it until the needle in the gauge stops moving, indicating highest compresion) and then write down the number you get. Most compression gauges have a check valve, so dont forget to clear the gauge before moving to your next cylinder. Repeat this process for every cylinder. It would be best to defeat the fuel pump so fuel does not spray into the cylinder as you are turning the engine over. The best way to do this would be to locate the fuel pump relay and remove it temporarily. Hope this helps
Old Mar 3, 2007 | 04:59 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
-all plugs out
-fuel pump fuse removed
-throttle wide open
-engine hot
Old Mar 3, 2007 | 05:14 PM
the numbers that you will get that will be optimal will be the "wet test" where the car is warmed up and you put a little bit of oil around the tester o-ring to get a tighter seal. try it both ways.
Old Mar 8, 2007 | 11:26 PM
B.Money's Avatar
Originally Posted by Billman250,Mar 3 2007, 05:59 PM
-all plugs out
-throttle wide open
-engine hot
okay perfect 1 last question for everyone tho. if this is ALL i need to know is w/ all plugs out test each cylinder by getting in the car flooring it and starting it enough to let the engine turn to get an accurate reading the LAST question i have for you guys is
where can i find the fuel pump fuse to remove it? and when i do i can just plop it back in and be good to go?? thanks guys!
Old Mar 9, 2007 | 09:36 AM
kchandra's Avatar
it on the drivers side fuse box assembly or something like that...
Old Mar 9, 2007 | 10:34 AM
silencertk's Avatar
get down and look under your dash kinda next to and up from - your hood release. there shoud also be sticker identifying every fuse.
