Compression Test Results
Old Jun 30, 2017 | 08:28 AM
s2000Junky's Avatar
Most in the know will tell you that consistency between each cylinders tells more of the story then the peak number since gauges/test conditions vary. Your numbers are very consistent. Try a different gauge if it bothers you and want to be more sure. Its not a hard test to perform yourself.
Old Jun 30, 2017 | 12:29 PM
jyeung528's Avatar
the consistency is good.
i would be okay with it
but for peace of mind, a leakdown will confirm.
Old Jul 1, 2017 | 08:05 AM
Car Analogy's Avatar
Originally Posted by darkvette07
The mechanic sent me pictures of the psi in each piston so I am sure he tested it. So it could be the gauge, cold test, or the engine itself has low compression. Will try and figure it out.
should I be worried if the compression reading are correct?
Excellent! Photos were a good idea on his part.
I am convinced this car is good. That HF gauge reads way low. I got similar readings, but when I used a decent gauge I was in 230 range...
Old Jul 1, 2017 | 05:01 PM
windhund116's Avatar
If the power is close to another S2000, with known good engine... you are prolly good to go.
jdblood202
Aug 9, 2014 06:43 PM
Jacksparrow
Jul 23, 2009 08:37 PM
Trigun
Oct 3, 2006 11:27 AM
jert534
Jul 18, 2006 06:38 PM
