Compression test results
Old May 2, 2009 | 07:53 AM
TelosHedge's Avatar
ummm.... what wires?
Old May 2, 2009 | 11:58 AM
lotus7racer's Avatar
What wires?
Regardless, there is a wire connected to the sparkplug coils right?
Why? Is there a wireless ignition now!
Old May 2, 2009 | 09:46 PM
TelosHedge's Avatar
if you're talking about the one wiring harness that runs along side the top of the valve cover you'd be pretty hard pressed to mix up the order. they are all chained together and only fit back on one way.
Old May 2, 2009 | 10:08 PM
S2K Sideways's Avatar
my car is basically Stock w/ Headers,test tipe and catback exhaust..I notice it not having the power it should have compared to friends' S2000's...It does consume oil over time, especially when i am driving hard (all the time) lol ...but thats something that is common in our cars no?
Old May 2, 2009 | 10:59 PM
Soul Coughing's Avatar
don't worry about the overall compression numbers. Each compression tester will be different. All you need to pay attention to is the percentage difference between the numbers. That is what is important when seeing if there is a problem. Now that you have found a low compression in a cylinder, you need to find out why its low. Pour a teaspoon of oil into that cylinder and redo the compression test. If the numbers jump up, you know its a ring issue. If it doesn't, its something to do with the head. good luck
Old May 3, 2009 | 04:42 AM
bgoetz's Avatar
I understand not paying MUCH attention to the actual numbers vs. the variance between cylinders, but damn if the numbers are that low across the board there are some SERIOUS issues with all cylinders.
I would do it again with the engine warm and hopefully those numbers are a heck of alot higher, although I doubt they are 120psi higher.
dsddcd
Feb 20, 2019 03:31 AM
darkvette07
Jul 1, 2017 05:01 PM
miskatcitnamor
Oct 4, 2013 02:33 AM
bd307
Sep 7, 2010 02:53 PM
