Comptech IceBox & Vortech SC
Old Dec 21, 2004 | 04:34 PM
fltsfshr's Avatar
Default Comptech IceBox & Vortech SC
Has anyone tried this? I know the Vortech sits a little less centered on the engine and wondered if a Comptech Box would still fit.
I've discovered the Vortech intake cost me Hp I'm wondering if the Comptech IceBox allows more flow
thanks
fltsfshr
Old Dec 21, 2004 | 05:27 PM
xviper's Avatar
I cleaned a Comptech filter for a friend when I was in San Fran. It might just work if you use the Vortech flex hose to the filter. However, that Comptech box is pretty big, so could be tight.
I'm using the JR filter that I made my own shroud out of a plastic plant pot.
Old Dec 21, 2004 | 05:33 PM
fltsfshr's Avatar
thanks xviper
I think Vortechs flex hose is part of the problem. What I was concerned about was the clearance between the box and the hair dryer as I think the two superchargers sit a bit differently. I face alot of heat here in the summer too so I'm still trying to bring in cool air through the fender. I thought maybe the larger box would help the flow. I figured on having to change the hose if I had to.
fltsfshr
Old Dec 21, 2004 | 06:10 PM
Sideways's Avatar
Flats,
Are you increasing the diameter of the intake and using a larger diameter filter?
X,
Good call on the JR. Back when stock, I dynoed back to back with just the change from factory filter to a used JR filter. It produced up a 2 hp gain.
Thanks,
S
Old Dec 21, 2004 | 07:17 PM
Slows2k's Avatar
I've done it, but you have to hack a huge section out of the Comptech box to clear the Vortech SC. It's either that, or remove the SC to install the box. (Not gonna happen on my car) I built a fiberglass plug to fill the hole, then covered the glass with foil tape.
The SC snail sits farther to the passengers side on a Vortech, compared to the Comptech. The angle the Comptech filter attaches is also different. I had to enlarge the opening to fit my allready oversized KN 1023 filter. I even used a "new" neoprene mousepad to seal the opening around the filter.
stena
Dec 4, 2015 07:43 PM
rikhemi
Jul 9, 2010 04:00 AM
mike10
Κινητήρας - Μετάδοση - Περιφερειακά
17
Nov 12, 2008 10:44 PM
God
Sep 12, 2006 01:01 PM
JayDeeEm
Mar 24, 2004 01:29 PM
