Comptech Intake
Old Sep 26, 2005 | 03:52 AM
SilverKnight's Avatar
ok go to pep boys and buy the k&n recharger kit which contains an oil in an aeresol can just liek comptech. Use that, i will buy one after work today
Old Sep 26, 2005 | 07:28 AM
Hockey's Avatar
No, no.....the K&N recharge kit is for paper filters. The Comptech is foam and has its own specific cleaner/oil kit. Just order it from Comptech. It works great and gets the filter back to original condition pretty quickly.
Old Sep 26, 2005 | 02:33 PM
hygiene boy's Avatar
NOOOOOOO........
the K&N filter recharge kit "IS NOT FOR PAPER FILTERS"
It is made for "Cotton Gauze Filters Only" , it will mess up and block airflow on a paper filter
I have used a K&N recharge kit on comptech foam filters before with no ill effects and no foam degradation over time.
Old Sep 26, 2005 | 03:54 PM
Nick , you have P.M. I may have the filter you've been looking for.
Anybody know the exact dimensions of a Comptech filter for a supercharger airbox?
Old Sep 26, 2005 | 05:13 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Ok....we may have been a little off base.
What we meant is, it's not for foam type filters like the Comptech.....I'll edit mine
Old Sep 26, 2005 | 07:01 PM
Ztec's Avatar
The Comptech ID foam filter flange is 5 1/2 inches and is the the same dimension long. I may have to make a custom adapter if K&N can't find anything!
Old Sep 26, 2005 | 07:15 PM
ok just got home from work.....ahhhh so tired but ok. Did lots of research on my break and even called comptech and k&n. The k&n can be used but you would rather want the thicker oil of the comptech since they are both diff materials. Its all aboutt weight. I was ablle to find a large can of uni foam oil and will spray her in a lil
Old Sep 26, 2005 | 07:20 PM
SC_Highlander's Avatar
Supposedly, an AFE 20-55507 filter will work in the comptech intake. The dimensions are: 5-1/2Fx 7Bx 4-3/4Tx 7H. I haven't had the motivation yet to order one and try it out.
Old Sep 26, 2005 | 07:30 PM
darkknight1999's Avatar
You guys know that the foam filters do a better job than the K&N if oiled properly right... K&N filters are known for letting a lot of dust and dirt into the engine. They make power due to the space in the filter. I've always had better luck with foam filters.
Old Sep 26, 2005 | 09:00 PM
folex187's Avatar
Where did you find the Uni-Oil?
