comptech replacement air filter
Old Mar 10, 2004 | 06:36 AM
sirrach's Avatar
Default comptech replacement air filter
I just installed the comptech replacement air filter and it is larger than the stock filter. When installing it, I had to push down a little on the airbox lid to latch it back on. Is this ok to do? Anyone else have this problem?
Old Mar 10, 2004 | 03:42 PM
sirrach's Avatar
anyone else have this problem? Anyone else actually buy this filter?
Old Mar 10, 2004 | 04:22 PM
S2KenC's Avatar
I have the blue comptech filter on my car. It fits perfectly just like the green oem paper filter does.
Check to see if the metal pin is attached to the left of the filter and is tightly connected to the bottom of the air box. Check to see if the plastic adapter that came with the filter is on snug with no gaps all the way around. Also, the plastic tubing has a goove around it. Make sure that this lines up with the stock air box before you place the lid on. I think this is causing the problem. Everything should fit perfectly.
Ken
Old Mar 10, 2004 | 04:37 PM
sirrach's Avatar
ok thanks, I'll check the groove and see if it is off.
Kyushin
Jan 4, 2007 10:11 AM
mknightx
Jun 12, 2006 06:33 PM
MDS2K
Dec 18, 2004 05:04 PM
Kibro
Apr 14, 2001 08:09 AM
Silver Bullet
Jan 13, 2001 09:01 PM
