Coolant leak - head gasket?
Hello All -
I have a 2014 Westfield S2000 that runs a 2001 Honda S2000 engine and trans. Just now I noticed that I have a very slow coolant leak on the exhaust side that appears to come from the interface between the block and head. It's right back between cylinders 3 and 4.
The engine has about 83,000 miles on it and I assume it's the original head gasket but I have no way to tell as I've only had the engine for the past 2 1/2 years and 7000 miles or so.
Have other seen leaks in this area? Am I right i assuming that it means I need a head gasket?
I've attached a photo of the car so you can get a feel for what a Westfield is - it's a modern version of a 60's-70's Lotus Seven and weighs a bit under 1300 lbs. Good fun.
Thanks in advance for your input and advice.
Dave
Dave
Thanks for the reply.
I cleaned the area well and took the car out for a drive and it was once again wet in the same area confirming that there is a leak and the area it originates. I would assume it could only be the head gasket if for no other reason as there's nothing else there.
I'm not sure a pressure test will tell me more......unless I don't understand the reason for the test.
Thanks again,
dave
Thanks again,
dave
Seems odd to me.
Advice:
Bore scope- look for a steam cleaned piston. I know u said only evidence is that it's actually seeping out the interface between the two.
Pressure test coolant system.
Cr test cylinders.
Is it smokin? Performance?
Sounds odd time and place to start leaking and if it was I would say it would be towards the piston.
Good thing is it looks super easy! To work on lol. side to side ease of access! Awesome whip.
Advice:
Cr test cylinders.
dave
Seems odd to me.
Advice:
Cr test cylinders.
Advice:
Cr test cylinders.
I agree that it might be a good idea to check it out with a scope and do a pressure test.......and at the same time it seems like the only place it can be leaking from is the head gasket so that it will need to be replaced. I don't know these engines well enough to say with 100% certainty that it's the head gasket but I can't see what else it could be.
Could it be something other than the head gasket? If so what might it be?
Thanks again -
dave
