Coolant Leaking From....
Old May 31, 2017 | 12:59 PM
eld101's Avatar
Thumbs down Coolant Leaking From....
So the other day I had noticed that my coolant was a tad low. I starting investigating why, and found some leaking coolant on the passenger side of the engine, just below the header. I thought, all of the coolant lines go to the heater above here, so one of the lines must be leaking, right? Wrong. It looks like they are all clean, and it is leaking from the block? :MAD:
I attached 2 pics, its hard to tell in the one, but the Vin or enginer number plate is covered, and the other pic shows the hoses that look pretty good. Any ideas what this could be leaking from? Its a 2001 with low miles. Let me know if any other info or pics are needed.
Thanks,
Eric
Attached Thumbnails Coolant Leaking From....-img_4569.jpg   Coolant Leaking From....-img_4570.jpg
Old Jun 2, 2017 | 03:29 AM
Slowcrash_101's Avatar
The engine coolant drain is under the header. It's a bolt and washer, if the coolant has been replaced that's my guess. Also your valve cover gasket is seeping oil.
Also the coolant is 50/50 water antifreeze. The water will evaporate over time, that's why every few years of daily driving your reservoir tank level will drop slightly.
Old Jun 2, 2017 | 04:06 AM
flanders's Avatar
Check the coolant lines above the oil filter also.
Old Jun 2, 2017 | 09:11 AM
jyeung528's Avatar
my coolant reservoir tank is old cracked and leaking, i just ordered a new tank from majestic. i have a 2003, perhaps yours is leaking as well.
Old Jun 3, 2017 | 04:59 AM
eld101's Avatar
Ill see if I cant find that bolt....hopefully it is that simple. As for the valve cover gasket, easy replacement?
Old Jun 3, 2017 | 07:52 AM
climhazzard's Avatar
Very easy - also a good time to do a valve adjustment if you're due. (That's not quite as easy, but isn't bad).
Old Jun 3, 2017 | 11:55 AM
flanders's Avatar
Here's a picture of an open coolant drain hole, just to the left of the oil filter.
Old Jun 4, 2017 | 02:14 AM
eld101's Avatar
Unfortunately the drain bolt looks dry. I did find a wet spot using the lighted mirror. It looks like it's just to the back of the header near the engine number. I'm trying to find my exploded drawing, but anyone know where this might be coming from?
Thanks!
Attached Thumbnails Coolant Leaking From....-img_4584.jpg   Coolant Leaking From....-img_4585.jpg
Old Jun 4, 2017 | 07:04 AM
Are you sure that's coolant and not oil?
Old Jun 4, 2017 | 07:12 AM
eld101's Avatar
Pretty sure, looked green yesterday but when I get home I'll give it another look.
