Coolant at Minimum?
Old Feb 10, 2002 | 02:51 PM
supernig's Avatar
Default Coolant at Minimum?
Every couple of weeks i find my coolant level at the minimum so i top it off to max with some water. I know i should use antifreeze but what i thought what happened is that water just evaporated and the mix was just a little more concentrated with the antifreeze? Like if you boil down salt water, the salt stays but water evaportates. So i added water to make up the difference, but every 4-5 weeks its back at minimum. Is this normal? I am sure there are no leaks.
Old Feb 10, 2002 | 02:56 PM
RT's Avatar
RT
I don't know for sure, but I've only needed to top off once in over two years.
Old Feb 10, 2002 | 04:12 PM
cdelena's Avatar
Look at the reservoir again.. there is a line high up that is just a line, the max line is low. I bet you are overfilling it and it just pushes the extra out the overflow when hot.
Old Feb 10, 2002 | 04:16 PM
boiler's Avatar
It HAS to be going somewhere. If you can't see any external leaks, it must be an internal leak, such as a blown head gasket. This is something the dealer should look into and fix for you. I wouldn't wait until the engine overheats. Get it fixed as soon as possible.
BB02s2k
Sep 10, 2012 01:43 PM
kylemonster85
Jan 22, 2009 05:39 PM
bitz
Jul 9, 2005 08:19 PM
DaWorm
South Florida
Aug 19, 2004 05:50 AM
OC S2K
Oct 26, 2003 09:38 PM
