Coolant Problem, Help please!
Old Apr 25, 2015 | 09:31 PM
s2k_4life's Avatar
Default Coolant Problem, Help please!
Turned off my car today and heard boiling/bubble sounds while in the cabin. Opened the hood and saw coolant residue all over the engine bay. Coolant level in the reservoir was low and the foam between the radiator and radiator support beam was soaked. In addition, I saw coolant on the top trailing along the entire length of the radiator.
Any suggestions on what to do?
Old Apr 25, 2015 | 11:12 PM
Habitforming's Avatar
Find the leak, which is probably on the upper plastic endtank of your radiator. Then if so, buy a new radiator.
Old Apr 26, 2015 | 12:13 AM
s2000Junky's Avatar
Make sure its not the cap. Ive had them go bad on this car before. The rubber gaskets dont last forever.
Old Apr 26, 2015 | 12:20 AM
s2k_4life's Avatar
yea, I will definitely be getting a new radiator cap. Judging from the photo and how the coolant residue looks on the intake arm and upper radiator hose, it seems like its all pointing towards the coolant reservoir though? Any thoughts? Could the reservoir be the problem?
Old Apr 26, 2015 | 12:51 AM
s2000Junky's Avatar
Its not a pressurized part of the system, so dont know why it would be the issue. If you are overheating for some other reason, then pressure could be pushed out through the reservoir. But thats not the reservoirs fault.
Old Apr 26, 2015 | 04:27 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Do you have a vented hood?
Old Apr 26, 2015 | 02:37 PM
s2k_4life's Avatar
negative on the vented hood.
I ruled out the reservoir because I found some more coolant residue on the hood prop facing away from the reservoir.
Right now, I believe it really is the radiator because when I opened my hood today after driving it for a while, the fan housing was completely wet and smoke was also coming off the housing and radiator. My guess is the top plastic part of the radiator that runs lengthwise that is leaking. In addition, when I turn on the heater to the max, Im getting inconsistent heat. Sometimes it will be hot then it'll turn to cool/warm then back to hot. Could it also be my thermostat? two different system failed together sounds a little bit odd though..
Old Apr 26, 2015 | 04:36 PM
When your radiator spewed coolant some of that space was replaced with air. I wouldn't drive the car at all with the problems you're having, you could damage the engine.
Can you not see coolant coming out with the engine running? Shouldn't be too hard to find the culprit.
Old Apr 28, 2015 | 11:07 AM
SheDrivesIt's Avatar
And like he said, stop driving it.
Old Apr 28, 2015 | 11:38 AM
Fisionboy's Avatar
I think you just have a hole in the hose between the cap and the reservoir. Looks like a cheap fix.
