Cooling mods work!
Old Mar 11, 2003 | 07:42 PM
TypeSH's Avatar
[QUOTE]Originally posted by gernby
[B]
Interesting.
Old Mar 11, 2003 | 07:51 PM
TypeSH's Avatar
FYI, I took out my Spoon thermostat and will be using a Mugen one instead. The Spoon runs an average of 10 degrees cooler than the Mugen. When I had the Spoon installed my cars water temp wouldn't get above 160 on my entire drive to and from work, which is about 8 miles each way. Not a good idea IMHO.
Old Mar 12, 2003 | 05:46 AM
Gernby's Avatar
Former Sponsor
I don't think the temp guage is displaying radiator temp. I think it is displaying the temp from the block. If it were displaying radiator temp, the temp would be cooler in higher gears (slower coolant flow and high air flow).
Old Mar 12, 2003 | 05:59 AM
MacGyver's Avatar
gernby,
I was in DFW (Irving) yesterday for a job interview...I believe the temp during the day was mid-70's. Side note...I'm realy hoping for this job to go through, and if it does, the better half is looking at a place in Plano. Anyway, you could put an electric valve on the radiator line with a switch in the cabin...close it completely during cold starts, open it partially during normal driving with full open for track events. Slap a simple timer on there to prevent Alzheimers kicking in and forgetting to open it up after warmup.
Old Mar 12, 2003 | 06:30 AM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by MacGyver
[B]gernby,
Old Mar 12, 2003 | 12:25 PM
Gernby's Avatar
Former Sponsor
I don't really know how to test the pump without using a flow meter, or possibly a pressure sensor. If there was a pressure sensor in the coolant line FROM the engine TO the radiator, and there was some sort of a restriction between the pressure sensor and the radiator, then it seems like you could plot pressure based on RPM. I don't think you could really calculate GPM from that, but a higher pressure would indicate higher flow, right?
Old Mar 12, 2003 | 12:34 PM
S2K_LA's Avatar
Sweeet! Exactly the type of conversation I was hoping to get
Old Mar 12, 2003 | 12:37 PM
KrazyKarim's Avatar
quick question a little off topic, i've been looking to get an OBD2 tool ot data log and scan and such, Anyone have any good reccomendations?
Thanx
Karim
Old Mar 12, 2003 | 12:40 PM
Gernby's Avatar
Former Sponsor
I like the Techtom (Here). It doesn't do datalogging, but it is a cheap multifunction "guage" with an OBD-II diagnostic code reader.
Old Mar 12, 2003 | 01:51 PM
Yellow Streak's Avatar
Thanx
Karim
http://www.obd-2.com/
