Correct upstream O2 sensor for AP1 w/F22?
Old Dec 12, 2016 | 11:18 PM
F1 blue's Avatar
Default Correct upstream O2 sensor for AP1 w/F22?
Would love to get some clarification so that I don't order the less-effective O2 sensor for my situation:
I've got an '02 with a 04-05 F22. I'm running the correct, unmodified ECU for the AP2 and need to change out the up-stream O2 sensor; should I buy the 04-05 sensor? I'm guessing that's the case since I'd think that F22 ECU would prefer to see that sensor.
amirite?!? Or.... no?
Old Dec 13, 2016 | 02:47 AM
Chuck S's Avatar
Makes sense. They're all the same part number other than the last 3 digits and may be interchangeable. Probably a Denso part (Honda didn't make them).
-- Chuck
Old Dec 13, 2016 | 03:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
00-03 sensors are different than 04-05 sensors.
Old Dec 13, 2016 | 06:10 AM
Topplayer's Avatar
get the 04-05 sensor,
Old Dec 13, 2016 | 10:50 AM
F1 blue's Avatar
Wonderful, will do.
and hello better gas mileage!
Old Dec 21, 2016 | 10:20 PM
MorngWoodStewie's Avatar
Did u go with a OE Replacement? Or NGK?
How's it working?
Went to the dealer the other day for upstream. Quoted me like $478!!!
Looking for reliable/performance/accuracy
I'm boosted on original, rounding 75k Mil.
any advice? $500 is a monopoly!
Old Dec 21, 2016 | 11:17 PM
s2000Junky's Avatar
OEM sensor cost is insanity. You can get an equivalent performing option in either a denso or ngk with direct pnp for less then $60 each! Both upstream and down are outfitted on my car. The only difference is the male/female connector. Based on my research, all Hondas use the same sensors but the pnp plugs are switched for the S2k, so for example the female/upstream on say a accord, is the male/downstream on the s2k, and vice versa. Get either brand, just make sure you got the right plug end for the right location. I dont remember which is which. You will probably have to crawl under the car to verify.
kaansahbaz
Nov 7, 2014 04:18 PM
HankookS2K
Oct 9, 2014 05:39 AM
chris2k03
May 9, 2014 11:06 AM
OC_
May 28, 2006 08:24 AM
