Corroded Control Arm Bushings & Camber
I managed to find a few threads which talk about control arms bushings rusting into the camber adjustment bolt. Which prevents adjustment of camber.
Has anyone had experience with this?
It seems that a visual inspection will not let you know , you can only find out by seeing if the bolt is free to move within the bushing. Aparently honda doesnt sell just the bushing so the only options are entire control arm, or aftermarket products,
http://www.kingmotorsports.com/product.asp...7&vehicle=S2000
is one place which is very decently priced,
I think the hard part of getting everything done, is that the bushings are pressed in? Im not really sure about that,
so i need someone with experience to let me know how the dealt with it
i may be past that stage , because i was told by an allignment tech that he had fully adjusted the camber and couldnt get it into spec.
Also happens to be the right side, where i can see the LCA has been replaced with used oem, and has some visible rust.
Apparently it isn't seized. The bushings may be deformed which is why it wouldn't go into adjustment. If the bushings were deteriorated, not only would the car not be alignable, the alignment would be constantly changing. Your car would be ALL over the road in this scenario.
warbucks
May 26, 2014 03:40 PM
SoCalIsMyLife
Sep 11, 2008 06:30 AM
Windscreen
Nov 19, 2006 05:24 PM
