Crackling noise from air pump
Old Aug 5, 2012 | 05:24 PM
trackrabbit21's Avatar
Default Crackling noise from air pump
http://www.youtube.com/watch?v=xHIUiZi45sI&feature=plcp
When the car turns on, air pump turns on, and instead of the high pitched noise, i've been getting a crackling noise as well, and it also stays on even when the car is warmed up fully. No CEL's for a faulty air pump. Could it be the relay? Or do I need to replace the air pump? Thoughts?
Old Aug 6, 2012 | 04:56 AM
http://www.youtube.com/my_videos_edi...id=xHIUiZi45sI
For some reason I can't see the youtube video, so here it is again
Old Aug 7, 2012 | 12:59 PM
bump
Old Aug 7, 2012 | 07:56 PM
bump
Old Aug 9, 2012 | 10:34 AM
bump
Old Aug 9, 2012 | 11:23 AM
realblag's Avatar
Video doesn't work
Old Aug 10, 2012 | 02:00 AM
bump videos been updated! Thanks realblag
Old Aug 10, 2012 | 12:10 PM
bump
Old Aug 10, 2012 | 09:31 PM
realblag's Avatar
It sounds like it has sucked something in or the motor on the pump has gone bad. Are you also saying it never turns off?
Old Aug 11, 2012 | 05:06 AM
Unbr3akable's Avatar
Sounds like your air pump relay is stuck "closed". Constant running of the pump will overheat and eventually destroy the pump.
There's a service bulletin on this:
http://www.izzeracing.com/2009-05-26_200503_411.pdf
