crank pulley timing
Old May 5, 2007 | 03:34 AM
GDM S2K's Avatar
Default crank pulley timing
I was puttingmy car ack together last night and noticed there are maybe 4 dips on the crank pulley for when you set timing. not 100% sure on which mark is the TDC mark. I believe its the first dip on the pully can someone confirm this
Old May 5, 2007 | 06:19 AM
Slows2k's Avatar
The white line is TDC
The red line is 5 deg BTDC
Old May 5, 2007 | 10:30 AM
jyeung528's Avatar
hmmm....you sure you're prepared to put your car back together?
Old May 5, 2007 | 11:24 AM
GDM S2K's Avatar
I was pretty sure it was the white one but in the manual it only shows 2 notches and on the pully there are more than 2.
_brandon
Jun 25, 2025 11:01 PM
grantedS2k
Jan 10, 2007 11:52 PM
530s2k
Dec 24, 2005 03:36 PM
BahrainONE1
Sep 12, 2005 06:58 PM
