Cross-threaded sub-frame member
Old Jan 30, 2005 | 03:04 PM
payneinthe's Avatar
Default Cross-threaded sub-frame member
I pulled the front sway bar mounts to put some loc-tite on them, since the sway bar (Saner) has been very noisy recently, and those bolts are often loose. I'm pretty sure this particular bolt got cross-threaded last time, and now it will not go in. The first two revolutions of thread on the bolt are completely filled with metal from the sub-frame. What can be done to fix it? Can I somehow clean up the threads on the sub-frame and buy a new bolt, or do I need to tap new threads into the sub-frame?
Old Jan 31, 2005 | 01:29 AM
AusS2000's Avatar
Tap the threads, dye the bolts!
You can tell I just bought a Tap and Dye kit can't you.
If course you will need a metric set but I'm sure they're not too hard to find even over there.
Old Jan 31, 2005 | 02:24 AM
RACER's Avatar
If he taps the threads, he'll have to use the next biggest bolt. There are other ways of repairing the threads to return them to normal.
He could just try cleaning the threads with the same size tap, then see what it looks like.
Old Jan 31, 2005 | 02:33 AM
AusS2000's Avatar
Oh, I'm not for one second suggesting he up the size. Just find out the size and pitch of the thread and run that size tap through the hole and that size dye up the bolt.
Sorry if I wasn't clear on that.
Old Jan 31, 2005 | 06:09 AM
Gernby's Avatar
Former Sponsor
If you don't have a tap and die set, then just get several new bolts and try running them through a few times.
Artisan7471
May 14, 2010 12:24 PM
99SH
Oct 28, 2009 08:05 AM
gomarlins3
Dec 27, 2006 07:44 AM
aronparsons
Feb 17, 2006 10:09 AM
Fongu
Apr 18, 2005 07:01 PM
