Cruse Control Troubleshooting
Old Jul 27, 2006 | 09:02 PM
iDomN8U's Avatar
Default Cruse Control Troubleshooting
My CC wont engage, the light on dash will not light up. Here's the summary
CC button lights up when pressed
I checked the Clutch switch with a volt meter for continuity (sp?) CHECK
checked the Brake switch (both switches in the one) for continuity CHECK
checked the steering wheel controls with volt meter CHECK
I also jumped the clutch swith with a paper click, still didn't work.
All fuses including under the hood are fine and under the dash.
Am I missing something??
Please help and thank you
Old Jul 27, 2006 | 09:33 PM
xviper's Avatar
The clutch pedal has 2 switches on it. One is for the starter interlock and the other is for the CC kill. Are you sure you checked the right one?
Did you check fuse #47 under the hood?
And fuse # 6 and #23 under the dash?
Old Jul 28, 2006 | 07:00 AM
iDomN8U's Avatar
[QUOTE=xviper,Jul 27 2006, 09:33 PM] The clutch pedal has 2 switches on it.
Old Jul 28, 2006 | 07:35 AM
xviper's Avatar
Originally Posted by iDomN8U,Jul 28 2006, 09:00 AM
From what I could see the plug that goes into the clutch switch only has a 2 wire plug.
What I'm trying to tell you is that there are TWO separate switches on the clutch. You are only looking at one of them. Check the OTHER one.
Skibum853
May 28, 2013 04:33 PM
Brndon
Feb 11, 2013 02:17 PM
AZ-S2000
May 1, 2012 01:01 AM
Presto123
Sep 14, 2010 05:15 PM
jamest16748500
Feb 17, 2010 07:36 PM
