Debris in diff half shaft/axle area....
Do you really want any foam, large or small, inhere?
Or inhere?
The insides being oily would actually help you trap the foam parts.
Pull the cover off, put it on a bench, get out the tweezers and tweez away
Anyway.. that is what I would do.
But I guess I allready mentioned that.
Another side note: it may be "just foam" , but crushed it could turn into a "sand like" substance, depending on the foam of course.
It would never be caught by the magnetic drain plug
so fine particles will stay in suspension.
Or inhere?
Or inhere?
Or inhere?
so fine particles will stay in suspension.I paid good money for this part, and am trying to sort it out with the vendor. I honestly don't feel comfortable installing the one I received.
Styrofoam is extruded polystyrene. It is a compressible "plastic". With the heat in something like the rear diff, it will melt and could form thin sheets of styrene plastic upon cooling where it will stay in that form till it gets hot again. I don't think you've got enough in there to cause any damage but then, it's not my diff, so I can have a pretty cavalier attitude about it.
If it were me, I would support the diff so that the hole points down and will empty when I flushed it with something like an engine degreaser. Then the particles will fall out with the flush. Turn it over and do the same to the other side. Rinse out well with a light machine oil. I'd then fill it with the proper diff fluid and run it in the car for one really good heat cycle where the diff will get to max temp (about 1 to 2 hour hiway driving. Come home and immediately dump the fluid while it's hot enough to carry any foam residue with it. Refill and repeat again. When the 3rd load of diff fluid is in, I would be happy enough to continue on my way. But that's just me.
Do you know what kind of engine degreaser I should use? Im thinking Simple Green? What would you recommend?
Thx again!
Originally Posted by xviper,Jul 18 2006, 09:08 AM
Don't hold me to this, but I've been told that Simple Green can be quite corrosive for some applications. You should go to an autoparts store and get a jug of the solvent they use in those parts washing trays - the kind that has the little pump and a nozzle to hose down the parts. That solvent will be safe for this sort of application. Sorry, don't know any brand names to give you.
Much appreciated
GPW03 Posted on Jul 19 2006, 02:37 PM
This is much worse then I had in mind.
Take the back cover off and rinse thoroughly!
IMO
And I hope the person who shipped it is watching this too.
Next time put the diff in a plastic bag!
And then "cover it" with foam for protection.
Here is a pic I took of the debris in my diff.
IMO
IMO
IMO
