delete please ty
Old Mar 14, 2013 | 01:09 PM
chos2k's Avatar
Default delete please ty
df
Old Mar 14, 2013 | 01:29 PM
chos2k's Avatar
to add on to it... oil seems to be leaking obviously. can't figure out where. jst leaking leaking dripping...
Old Mar 14, 2013 | 02:01 PM
RedSunS2K's Avatar
check the if the valve cover gasket has been damaged. also check if the spark plug seals are seated correctly over the spark plug tubes. Are you sure it's oil? Oil doesn't burn white.
Is there something special about your valve cover that he needed to track it with? What's was wrong with his? I hope he actually gave you back YOUR cover and not his own.
PS. If your friend doesn't appreciate what you did for him then never let him borrow anything again!
Old Mar 14, 2013 | 03:11 PM
RedSunS2K's Avatar
Stop driving the car until we figure out the issue. If its leaking from the side like that it could be the valve cover gasket. Or maybe the valve cover isn't tightened enough.
s2000maniac's Avatar
get a new valve cover gasket. or check the current one as might have been cracked or ripped.
Old Mar 14, 2013 | 06:23 PM
steven975's Avatar
oh and use a torque wrench to put that cover on. 8.7 lb-ft isn't very much.
You don't want to be driving a car with oil leaking onto an exhaust manifold. Unless you like your car extra crispy.
Old Mar 14, 2013 | 06:43 PM
chos2k's Avatar
yessir :3
gonna be picking up the seal tomorrow and hoping that'll do the job... and fix whatever issue it might've had..
and of course not driving it til it's fixed... sad thing is my other car's window shattered yesterday and having helll of a pain repairing it because parts of the regulator got shattered glass into it so it's giving a lot of stress grinding and pulling all that glass out
thanks for looking out!
also as far as torque goes. i read it was around 8~10 and I have been just doing as hard as a hand can as most advised... i was wondering, when you put the valve cover onto the top... only way to tighten is through the bolts right??? i wish there was a way to tighten it a bit more :/
Old Mar 14, 2013 | 08:29 PM
Murphg05's Avatar
Don't understand why oil leaking onto the exhaust manifold would affect the way the car is running?
Even if you replace the gasket and stop the leak, I don't think it would change your not being able to go over 4k issue. Something else must be going on there.
Old Mar 15, 2013 | 12:16 AM
chos2k's Avatar
i hope so mannnn. car was clean *_* but now ruined sigh... cel checking atm... keep you guys posted. thanks for all the advices and such and such...
Old Mar 17, 2013 | 03:58 AM
RedSunS2K's Avatar
If I can recall, there are a few things to disconnect when you take the valve cover off. Make sure EVERYTHING is put back in place.
